for you problem solvers....
Old Jul 13, 2013 | 02:34 PM
robsryd's Avatar
Ill make this short; '87 Z28, column issue. wheels straight and factory steer wheel straight, turn signal cancellation short to left, long on right.
Then I try to install grant wheel. wheels straight, grant wheel crooked, turn signal cancellation normal.
Both scenarios the horn tube lines up.
I you have any solid diagnosis, please help.
Old Jul 13, 2013 | 06:41 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: for you problem solvers....
Put the old wheel back on and set to your first description. The remove steering shaft from steering box, turn till the steering wheel is straight and reattach. Then swap to the grant wheel. That should fix it.
Old Jul 13, 2013 | 06:44 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
The grant wheel adapters usually have 2 positions they can be installed in, atleast mine did. I put it on the wrong position the first try, the horn button and everything lined up, but the wheel was crooked.
Old Jul 14, 2013 | 01:43 PM
robsryd's Avatar
92 rs....Old wheel is on, and straight, but the turn sig are not centered.
Travis.....Ill check that out.
Old Jul 14, 2013 | 03:25 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
robsryd - Yes, that's when you recenter the steering shaft on the steering box. Your old wheel is actually on crooked. Noormally you would then remove the old wheel, turn it to where it is straight, and then put it back on. Your whel is then straight, and your turn signals are centered again. Its a common problem after an alignment issue has been corrected.
travis401 - I don't remember my Grant wheel adapter having more than one hole for the horn button.
Old Jul 15, 2013 | 07:00 AM
robsryd's Avatar
Gotchya! Going to try after this heat wave we here in the northeast are going through. Even in my small garage its too friggin hot.
Il'l let you know how it goes brutha.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
