Steering wheel
Old Jul 19, 2013 | 11:44 PM
BftCamaro's Avatar
Car: 1987 camaro Z28
Engine: 5.0 TPI LB9
Transmission: 700r4 auto
Axle/Gears: 2.62:1
Steering wheel
I was just wondering if anyone would know if I'm able to attach a zl1 or corvette steering wheel to my steering column ? BTW I have a 87 z28
Old Jul 24, 2013 | 12:07 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Steering wheel
If you're talking about current or late model cars, then the short answer is no. The hubs on the newer GM cars are MUCH larger than the standard 1969-up GM square key columns. I'd guess the number of mounting splines is different as well, which will be your real problem.
With enough fabrication it could probably be done, but it's not a simple "just remove the old one and bolt in the new one" swap.
BTW, did you know that the current Corvette wheel was also used in everything from Saturns to Malibus? The ZL1 wheel is basically the newer version of that wheel, and is also now in many of GM's other lesser cars. Personally, if I'm going to take the time to swap my steering wheel, I wouldn't want to end up with the same thing that some old blue-haired lady has in her Cobalt.
Just a thought.
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
