Center Console Replacement
Old Aug 2, 2013 | 03:17 PM
steveschau's Avatar
I bought a center console for my 98 Firebird and need to know how to remove the automatic shift handle. Anyone done this before?
Old Aug 2, 2013 | 03:27 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Center Console Replacement
Put the key in the ignition, put it in the "run" position so that you can move the shifter all the way down to 1st gear. After you have it in 1st gear, you'll be able to see the u-clip that pulls out at the backside of the shift ****. Pull the u-clip out, and the **** should come right out.
Old Aug 2, 2013 | 03:34 PM
steveschau's Avatar
Pull it out how or with what kind of tool. I see what you are saying just dont know how to get that u-clip out.
Old Aug 2, 2013 | 04:15 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
Ice pick, pocket knife, small flat-blade screwdriver
Old Aug 3, 2013 | 11:04 AM
navy02ws6's Avatar
Pair of needle nose pliers works too, or even a fork or kitchen knife if you're in a bind. Just need something metal to stick behind it and pry it out.
Old Aug 4, 2013 | 09:36 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
The thing you need to pull out looks like a staple. The first time I tried this, it went flying and I couldn't find it. Make sure you're careful!
1992 Trans Am
May 10, 2023 07:19 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
colton_carlson
Mar 8, 2019 12:21 PM
Firebird sweden
Aug 16, 2015 05:02 PM
TheJoeY88
Aug 13, 2015 06:51 PM
