Steering Column Help. (Franken Column)
Old Aug 8, 2013 | 01:02 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Okay, so I had the problem with the loose tilt mechanism and all that jazz, I tightened it once. Didn't help much. Wiggles like freakin rope on a horse. SO, today I picked up a new (used) steering column from the junkyard. Okay, so it is a tilt wheel, and it had this steering wheel:
Anyways, I took it off, and it looks like some parts are broken under the broken housing, and this is the housing I am talking about:
SO, the question is, is there some way I can just get the tilt mechanism out of the overall bad steering column, and put it in the overall good column?
Edit: I didn't really look to much into either column once I got it home, because it started to rain. Just encase this is a stupid question.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Tweeks25
Sep 17, 2015 08:04 AM
383cam
Sep 9, 2015 06:01 AM
SG91camaro
Sep 5, 2015 10:27 PM
Ian Irvine
Sep 4, 2015 08:08 AM
