Full 4th gen interior swap into 3rd gen Camaro?
Old Aug 20, 2013 | 02:58 PM
Jared N259's Avatar
I'm planning out my Camaro build for next year and I'm currently working on the interior plan. I honestly prefer the interior of the 4th gens over that of the 3rd gens and was wondering if it would be feasible to do a complete interior swap. I know that some might consider this sacrilegious to completely swap the interior but I'm not sure if I care. I'm planning on completely stripping the interior no matter what so I see no reason why when I put a new one in I cant just put in the different interior. Thanks for the information!
Old Aug 20, 2013 | 06:19 PM
toomany's Avatar
Re: Full 4th gen interior swap into 3rd gen Camaro?
This has been discussed a ton on here, if you search you should find some answers.
That being said. Dash, counsel and seats are fairly easy. The door panels are a bit of a challenge to get to look correct. Needs some fiberglass work IIRC. The plastic pieces aren't really going to go in without a fight. The interior shape of the cars are too far apart.
Old Aug 20, 2013 | 11:36 PM
Jared N259's Avatar
I did a search and I got partial answers but nothing relating to a full swap. What im really interested in is the dash, door panels, and console. I could live with the stock panels if its too much of a pain in the ***. While im currently planning on 4th gen seats I may change that later on. what difficulties would I have with the carpet kit? I'll stick with a 3rd gen headliner but with the 4th gen console I'm not sure about the carpet kit.
Old Aug 22, 2013 | 03:08 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Headliner won't fit door panels can be easy but do have to be modified and molded to fit dash console and seats are easy not sure what you mean by carpet kit? 3rd gen carpet will do just fine if yours is worn replace it with new or used 3rd gen carpet
Old Aug 22, 2013 | 05:48 PM
Jared N259's Avatar
That's what I'm thinking, 3rd gen headliner + carpet kit, 4th gen Dash, Console, seats, and door panels.
Old Aug 22, 2013 | 09:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Many members have done this and there are complete threads about this. For instance the Camaro member of the month has a complete fourth gen interior, PM him and ask for links or pictures or advice. I do wonder if you know how many hours of work are involved in doing a complete swap..... Everything has to be rewired and cut to fit, no way around it. People loosely throw around the phrase "winter project" but I am guessing that this is a true winter project. For instance I made a new gauge cluster with aftermarket gauges and between making the new gauge cluster plate and wiring them in I have around twenty hours in it. You're doing an entire interior, do you really have the time for a 100 hour project? If so good luck.
Old Aug 22, 2013 | 09:29 PM
Jared N259's Avatar
No matter what I do I plan on pulling the seats out, replacing headliner, door panels, carpet kits, center console, and possibly dash, the question was whether or not I was going to put back in 3rd gen or 4th gen, I expect the rebuild of this car to take at least 6 months if it all goes, smoothly. which it never does so Im estimating at least 8 months of hard work before this car is ready to roll.
Old Aug 22, 2013 | 11:03 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
8 months is a lil more than it would take for a interior swap if you do your research, get your materials together and are handy with electrical and fabrication should take you a month if that
Old Aug 22, 2013 | 11:11 PM
Jared N259's Avatar
I was saying 8 months for the whole thing, I'm thinking 2 months for the interior depending on how much time I can spend on it...
Old Aug 23, 2013 | 12:09 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Gotcha was thinking you were only doing the interior need any help I'm doing the door panels and have already swapped in dash and console
Old Aug 23, 2013 | 12:15 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Look for the user Shroom on here. He did something similar (the RIGHT way), and has it all documented on his website. It's way more work than you think. =)
Old Aug 23, 2013 | 12:17 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
No need to go absolute crazy like shroom did but yes he did very nice work
Old Aug 23, 2013 | 12:30 AM
Jared N259's Avatar
Well I'm not doing mine till next fall, saving the money to do the whole car ( and buy it, have an 86 fbird right now) but I would love to see pics of it as it goes along, any advice you can give on the door panels would be appreciated. I hear they are the difficult part of the swap.
Old Aug 23, 2013 | 12:43 AM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Build thread is in sig links to dash console and there's links to the door panels that I'm in the process of doing throughout the build
Old Jan 4, 2014 | 08:56 PM
86F.BiRD's Avatar
Car: 1986 Pontiac Firebird Base
Engine: SBC 350
Transmission: Borg Warner T-5 World Class
Axle/Gears: 4th Gen Rear with 3.73s
I have already done the easy 4th gen seat swap, and my firebird's center console is worn badly. My question is: is the 4th gen console a simple bolt in process or is there any modifications needed to install it the right way? Thanks!
Old Jan 4, 2014 | 09:49 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
If you have all donor parts no reason you cat get it done in a few weekends time. Ive done a few Complete swaps. Dash,doors,console,etc... Have everything sitting here to do my current 92 vert.
If ya do a google search for 4thgen dash swap and put thirdgen.org in the search Tons come up also.
Old Mar 31, 2014 | 04:21 PM
fatalicshock's Avatar
Car: 87 Trans Am
i have the i think the 99-02 center console and it bolted right in no problems i really want to know what goes into swapping to 4th gen door panels i have a buddy that has a really nice set of black leather ones i think would look awesome in my car
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Linson
Aug 21, 2015 02:12 PM
reiderz iroc
Aug 13, 2015 04:57 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
