Tachometer Install??
Old Oct 28, 2013 | 07:43 PM
AaronEnde's Avatar
Car: 1991 Firebird T/A
Engine: 355 small block
Transmission: GM turbo350
Axle/Gears: .373
Hello, I have a 1991 Firebird. I was wondering how you go about installing an aftermarket tach, Like what it has to be wired into and stuff?? thanks for any help!!
Old Oct 29, 2013 | 07:18 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Tachometer Install??
Well they do come with good instructions but the general way they wire up is, green wire to coil, black wire to ground.red to ignition on wire, white to instrument lights.
Old Oct 29, 2013 | 02:44 PM
AaronEnde's Avatar
Axle/Gears: .373
Thank you, Much appreciated!
Old Oct 29, 2013 | 03:23 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Check youtube for installation videos or go to the manufacturer's website for step by step instructions.
Old Oct 29, 2013 | 04:26 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The only hard part is figuring out which terminal in the fuse box is for the interior lights. It has a kind of vague label, if I recall...
Old Oct 30, 2013 | 07:42 PM
AaronEnde's Avatar
Axle/Gears: .373
Thanks guys, Tach is in and works great!
Old Nov 1, 2013 | 09:35 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You can also pull the cluster and tap into the appropriate wire there.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
toones
Jan 6, 2016 06:00 PM
ChevyZ71
Aug 13, 2015 07:30 AM
