My first interior resto
Old Nov 17, 2013 | 06:52 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
I've been waiting over a year to do this and now I finally have the chance.
So here are my plans:
Raamat the entire floor, doors, and roof
replace the carpet
reupholster the seats and door panels
upgrade audio system
since the door panels will be off I will replace the window motors
I will probably have some questions for those who have been where I am going.
Here is the before
Everything is now out
Old Nov 18, 2013 | 05:44 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: My first interior resto
Well the floor pans are in great shape so that is one thing you you need not worry about.
Old Nov 18, 2013 | 08:30 AM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Yes, I was really happy to see no rust but being a Texas car, I'm not really surprised.
This glue they used to hold down the juke padding is a little overkill. I will be "grinding" most of that off.
Old Nov 22, 2013 | 10:00 PM
RQ Jay's Avatar
Car: 1985 TransAm
Engine: 4bbl 305
Transmission: Automatic
Is it necessary to grind that off? I am doing my complete interior over as well and was wondering if there was another way to remove it..
Old Nov 23, 2013 | 09:44 AM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Is it necessary, probably not but when I lay down the raamat I don't want any large bulges. This stuff is really sticky and unless I go down to bare metal I wont get it all off. I did manage to get most of the juke padding off using an 80 grit grinding disk.
Old Nov 23, 2013 | 10:17 AM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
I got most of the Juke padding off.
Since the carpet was out I figured now would be a good time to weld in SFC's.
I finished plasti dipping my new steering wheel.
Old Nov 23, 2013 | 01:02 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
what steering wheel is that
Old Nov 23, 2013 | 03:49 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Momo Millenium sport
Old Nov 23, 2013 | 06:48 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Raamat is pretty good stuff. I have 50 sq.ft. going on my doors and front area. I'm in the middle of redoing my interior.
Link with pics in my sig. Might help you.
Old Nov 24, 2013 | 07:20 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Don't take the rest of the "glue" of the floor, it wasn't to glue the padding, it's the seal for the body plugs, just happens to get stuck to the padding.
Old Nov 26, 2013 | 04:10 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Ok, not touching the rest of the glue. I got it down pretty flat anyway.
Started tackling the SFC's today and what a PITA! Doing the drivers side first and noticed the gas/brake lines. I know some people just move them a little out of the way but welding around gas lines scare me. So I tried to take them out and that proved to be more of a pain. With both sides undone I stretched them to the other side and that gives me plenty of room to weld. However now there is gas that leaked out from when I disconnected them from the fuel pump and brake fluid on the ground. I washed all that away and letting it dry for the rest of the day and will start to weld tomorrow.
I have the front on ramps and the rear axle on jack stands. Does anyone know how to tell if the car is completely level?
Old Nov 26, 2013 | 04:54 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Cool project. Keep us posted. Are you sending the seats out or going to try to do them yourself?
Old Nov 26, 2013 | 05:17 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
I'm going to take them to a local upholstery shop to do custom seats and door panels.
I wanted a different look from stock but need to keep the gray since the plastics, carpet, and seat belts are gray. So I was thinking black with gray inserts and dark blue (to match the paint) stitching.
Old Dec 4, 2013 | 06:12 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
So I got the subframe connectors in but since this is not a SFC thread I wont go into too much detail. I'll just say I never want to do that again.
And if you're going to attempt it, make sure you have a lot of room between the ground and the car. Car ramps do not raise the car high enough.
I had to drop the exhaust to get the passenger side done.
Some cutting had to be done on the heat shield by the catalytic converter.
Old Dec 4, 2013 | 06:17 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
I started the raammat installation and got most of the interior covered. Instructions were to only do 50-60% coverage, but I think I got a little more than that. Doors are not done yet.
Old Dec 19, 2013 | 07:58 AM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
It's been a while since I have been able to do anything due to the freezing temperatures and having a kid in out of the hospital for 2 weeks and I got really hungry.
The tops of my door panels have ripped where the door panel rails connect.
Looks like I have a few choices here.
1. Fiberglass over it to make a stronger panel and give the rails something to grab onto
2. make a whole new panel out of Masonite (recovering the door panels anyway)
3. fabricate 4th gen door panels to fit.
Speaking of door panel rails...
looks like mine have seen better days. I definitely need to replace the inner sweeps and the rail has a chunk broke off.
I saw this on 1a auto but not sure if that includes driver and passenger side.
http://www.1aauto.com/1A/Weatherstri...55/276746/1989
My other option is to epoxy the piece back together. But I still need to replace the sweep.
Old Dec 19, 2013 | 08:16 AM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
My driver side windows seems to have an alignment issue. Is this common?
I tried to push it in so the window clip slides into the window felt but after it rolls down it will not go back in. I have also tried to adjust the felt piece but I get the same problem.
It also affect the upper weatherstrip when closed. It does not get a proper seal.
Looking for help on this one.
Old Jan 3, 2014 | 04:55 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
I wasn't having issues with my window motors but I figured since they are almost 25 years old and I would be covering up the hole with ensolite that I might as well change them.
Old and new
I thought I had taken a picture of them installed but I guess I forgot.
After drilling out the rivets to remove them I used loctite red on the supplied screws to make sure they do not come off.
I ran out of ensolite so I had to order more to finish the doors but it hasn't come in yet. Here is what I have so far.
I found a compass/temperature mirror so I ran new wires for that. Works great.
I also manage to install a keyless entry system with hatch release. For anyone wanting to do the same here is the wires I used.
Old Jan 4, 2014 | 12:42 AM
Richboll's Avatar
Engine: 305 TBI
Looks good so far, looking forward to seeing the seats refinished. What did the temp/compass mirror come out of? Do you want to sell your old steering wheel? If so pm me with a price. I'm in Plano. Thanks
Old Jan 4, 2014 | 01:29 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Looks like youve done a few of the mods ive already done the temp/comp is a nice thing to have as well as the keyless entry. As for the 4th gen door panels they require some work hardest part is getting the door handles to fit/work the same as factory plus the unsightly gap they leave at the bottom but oh well doesnt bother me much but others dont care for it. Either way looks good so far keep up the work
Old Jan 4, 2014 | 01:46 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
I thought about hanging it on the wall in my office but not sure yet. If I decide to part with it I'll let you know.
Old Jan 4, 2014 | 02:01 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
I noticed how those with the overhead console can retrofit in a homelink device from a Cadillac. I wanted a homelink installed but I don't have a overhead console. So I found this in the junkyard. I don't remember what vehicle it came out of but it was attached to the sun visor.
I put it where no one would see it. Right above the cigarette lighter.
I used a dremel to cut the hole. The dash was a bit thicker than the space between the unit and the plastic face so I had to trim it.
I tapped into the same power I ran for the mirror. I don't like the fact on most homelinks you can open the garage with the car off. Easy for someone to break into the car and open the garage.
Old Jan 4, 2014 | 09:54 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i like that, i have the comp temp mirror in my car but id be interested as to what that came out of
Old Jan 5, 2014 | 06:08 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
1997-98 CHEVY SUBURBAN
Old Jan 5, 2014 | 06:20 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
the homelink did? the homelink for the overhead consoles is entirely different from what i know.
Old Jan 5, 2014 | 06:45 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
sorry, I thought you were referring to the mirror.
I'm not sure what car the homelink came out of, I want to say it was a chrysler sebring.
Old Jan 5, 2014 | 06:51 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Next on the list is to install the wiring for the new audio system.
I need to paint all the plastics but it's kind of difficult with temperatures below 50's.
Old Jan 5, 2014 | 06:56 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
if i may add some input, i would not use spray paint, SEM makes some very good dyes and adhesion promotor, id recommend that, scrub the plastics with some dishsoap and TSP and then follow that up with some mineral spirits after it dries.
Old Jan 5, 2014 | 07:06 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
This is what I have.
Old Jan 5, 2014 | 07:14 PM
Chad85T/A's Avatar
Car: 85 T/A
Old Jan 5, 2014 | 08:21 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
good ****, make sure to get all the oils off before hand, tsp and dish soap work great then follow that with a mineral spritis wipe down after
Old Jan 19, 2014 | 02:56 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
I was cleaning up the plastics and intended to keep the carpet on the plastics but some just started breaking away. So I removed them thinking I would just get a carpet kit and replace with new. However since it is off I am now thinking of vinyl wrapping all the plastics. Has anyone seen the interior all wrapped have their interior wrapped?
Old Jan 19, 2014 | 04:03 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
not of a thirdgen but ii did it to a 86 cutlass drag/show car at the interior shop i worked at.
ill be wrapping my dash and steering wheel in perforated vinyl and i thought about the plastics but thought itd be too much.
Old Jan 23, 2014 | 03:29 PM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
In post #16 I mentioned the door rails and the cracks. In addition they are warped/wavy by the window sweep/weatherstripping so I've decided to order new ones with sweeps attached.
Also before I can finish the door ensolite I noticed my car suffers from FDHS, Floppy Door Handle Syndrome*. I need to address that before closing it up.
Being in the middle of winter and since I need my seats recovered anyway I figured I would add seat heaters. These are carbon fiber heating pads. The high setting will have a constant range between 120°F to 125°F. The low setting ranges between 110°F to 115°F. Best part is the switches are rectangle like the window switches in the console. When installed they will look factory.
*FDHS is a common issue that affects 1 in 3 third gen camaros. Symptoms include loose door handle and possible rattling from affected area. Door handle is probably missing the retention wire and would need to be replaced. If you also experience a burning sensation when urinating or frequent diarrhea, seek medical attention immediately. This is not a symptom of FDHS.
Old Jan 23, 2014 | 05:48 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
whats the switch from?
Old Jan 23, 2014 | 05:51 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
You could look into getting hydrographics applied to your interior pieces
Old Jan 23, 2014 | 06:40 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
i beleive a member on here did all his in carbon fiber
Old Jan 23, 2014 | 10:52 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
buggydiaster
Old Jan 23, 2014 | 11:27 PM
solaris_vii's Avatar
Car: 1997 z28
Engine: lt1
Transmission: t56
[/SIZE]
lmao this is funny **** right here!
Old Jan 24, 2014 | 04:46 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Originally Posted by 86_irocz-28
buggydiaster
jirkaSS was his username i thought theres probably a few people
Old Jan 24, 2014 | 08:27 AM
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Seat heaters
Old Jan 24, 2014 | 08:37 AM
  #42
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
I decided to keep with originality and paint them. I already bought the prep and paint which wasn't cheap so I'm going to stick with that.
I ordered a carpet kit from Third gen ranch. Anyone know the best way to apply the carpet to the plastics? I was thinking of using 3M Super 77 spray adhesive.
Old Jan 24, 2014 | 11:58 AM
  #43
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
It comes pre-molded,no need for adhesive.
Old Jan 25, 2014 | 07:26 AM
  #44
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
Not the floor carpet, the cut pieces that attach to the plastics.
Old Jan 27, 2014 | 01:00 PM
  #45
mantaguy's Avatar
Engine: 5.0 EFI
O I C,didn't read the prior post,I would give the 3M 77 a shot,but I don't know how it would hold up the the summer heatI use it quit often and it's never given me any problems.
Old Jan 30, 2014 | 04:13 PM
  #46
dieseldog's Avatar
Car: 89 IROC-Z
Engine: L98 TPI
It's like a camaro Christmas
Door panel rails
upper console
Deluxe front seat foam
Door weatherstripping
Roof rail weatherstripping
carpet kit for plastics (with included contact cement)
Seat heaters
Old Feb 2, 2014 | 12:32 AM
  #47
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
WOW and I thought my floors where clean and I live in Canada where they salt everything like its goin out of style.
I got to ask. What is this homelink thing? Ive never heard of it before and what does it do?
I like the heated set idea for sure man. Where did you ge the kit and switches for it as its something Id like to do as I was working on my car last week when it was -22 out. Had the car running for heat but it would be nice to have the warmers as well
Old Feb 2, 2014 | 06:30 AM
  #48
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
Home link is a garage door opener.
Old Feb 2, 2014 | 10:49 AM
  #49
87350IROC's Avatar
Car: 87' IROC
Steering wheel looks MUCH better with the center black. I like that wheel and had thought about having the center anodized black. Did you remove the material or just tape and spray?
Old Feb 2, 2014 | 12:51 PM
  #50
Car: 89 IROC
Being in the middle of winter and since I need my seats recovered anyway I figured I would add seat heaters. These are carbon fiber heating pads. [SIZE=6]The high setting will have a constant range between 120°F to 125°F. The low setting ranges between 110°F to 115°F. Best part is the switches are rectangle like the window switches in the console. When installed they will look factory.
Need more info on the heated set kit and switches. Just what I need to convince the wife to join me for some cruising
