turn signal question
Old Nov 30, 2013 | 06:02 PM
Sam L.'s Avatar
Car: 1990 Camaro Iroc-z Z28,1987 Camaro
Engine: 406 Super rammed SBC, LT1 355
Transmission: 4l60E, 700R4
Axle/Gears: disc brake 3.27 9 bolt posi,10 bolt
hey guys,
so just the got steering column back in the car, blinkers and cruise work but now the highbeam light on dash does not work also when i put it in the seat belt light stopped working to any ideas??
Old Nov 30, 2013 | 06:34 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Re: turn signal question
seatbelt light i have no clue ... but as far as the high beams, make sure the rod did not pop out of the switch and make sure the switch didn't get moved when it was off (http://larkhawk.com/trans_am/high_beam_switch.jpg)
Old Dec 1, 2013 | 12:15 PM
Sam L.'s Avatar
alright checked it the rod did slip thanks for your help man!
Old Dec 1, 2013 | 07:43 PM
Barlow8869's Avatar
your welcome, glad it was an easy fix
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
