Painting Plastics
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
Painting Plastics
Well i have decided that i want to go all black interior on my 82 z. My interior is grey, going to die my carpet black. and im wanting to paint all my plastics from the stock grey to black.. ive did a little research on painting the plastics, and heres what i have gotton, thought about hitting them with 1000 grit to rough it up also... 2-3 cans of the SEM Gloss Black http://www.tcpglobal.com/itemdetail....no=SEM%2015233And a quart of the plastic prep
http://www.tcpglobal.com/itemdetail.aspx?itemno=SEM%2038354
is this a good product? anyone ever used the gloss black?
Re: Painting Plastics
If you are looking for something closer to the original sheen, you should go with Landau black. The gloss black is going to be a lot shinier then the original panels.
right, how many cans do you thing it will take?
Car: 83 Z28/L69
Engine: L69 305H.O.
Transmission: 6spd T56
Axle/Gears: 4.10 LS 4th Gen
I love SEM's products, but the high gloss black doesn't look right on interior panels, IMHO, I prefer the landau black. It looks like factory black. The gloss look like it was spray painted.
The prep is a good idea. I do have a tip for you before you start. Wash the panel in Windex 3 or 4 times. The Windex will pull the oils like armorall and such out (a gal of Windex is a lot cheaper than prep products), then sand, then prep, then paint. start with light coats of color.
Good luck and post plenty of pics!
You will probably need at least 4 cans. Here is how I prepped my plastics. I used simple green degreaser, as it is fairly strong and pulled off all of the grease and oils. I used a scotchbrite pad to scrub them to deep clean the panels, and rough up the surface for paint. Then I used bulldog adhesion promoter on the panels, followed by 3 light coats of paint. Since you are looking to do a color change, you may need more coats.
alright, thanks for the input guys! plan on doing this, this coming weekend. will post pics!
Car: 2001 Firehawk, `86 Trans Am project
Engine: LS1 in both
Transmission: T56 six speed in both
I agree with all that everyone posted above. You may want to see my thread here on restoring interior plastics and carpets, with pics. I think I used about 4 cans total as well:
https://www.thirdgen.org/forums/inte...ic-carpet.html
i think im going to rit dye my my carpets. and yes i was reading your thread earlier great stuff. yours looks like it just rolled outta factory!
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
I'm interested in seeing this completed. Can you post some before and after shots along with your thoughts on how it looks up close and personal?
Thanks!
Thanks!
yea man i will im gonna be doing this in the next week or so. im excited to see the results. what do yal think. all black interior plastics ,carpet, and headliner. with red door panels and red arm rest ive found these. http://s215.photobucket.com/user/mcg...tml?sort=3&o=1
http://s215.photobucket.com/user/mcg...tml?sort=3&o=2
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
will be ordering all the paint thursday(pay day). im gonna go ahead and paint my floor pans while my interior is out. i noticed some surface rust. and my passenger side floor is not bad but needs to be taking care of. had a bad heater core when i bought it figure thats what that sides the worst. any way whats some good paint for stopping and preventing rust?
Car: 83 Z28/L69
Engine: L69 305H.O.
Depends on your budget. POR15 works good, but pricey. Eastwood make some stuff just like POR15, cheaper.
http://www.eastwood.com/rust-encapsulator-28601.html
If it is just light surface rust, wire wheel it real good and brush on some 9.00 qt of walmart Rustoleum.
EDIT: I know OT, but if you haven't found good doors yet, I saw 3 3gs at Knoxville Pull A Part last time I was up there. Not sure how far you are, but thought I would mention it.
its not bad at all. ill prolly just go with some of the rustoleum.
Axle/Gears: G92
I used this (the link price is for 2 gallons). http://t.homedepot.com/p/Rust-Oleum-...402/202058828/
I scuff sanded, use rust converter, primed, then painted
https://www.thirdgen.org/forums/albu...0&ref=gnr-next
Well after i completely got my interior out.The car is really solid..... for the most part.......... real busy weekend so didnt get much done. Today i hit them with the wire wheel. and what did i find? Rust!. ..i couldnt believe what i found. i noticed 4 or 5 little rust holes on the passenger side. under the dash. same on the drivers but not as bad
.. this kills me.. i have the interior completely out and everything else looks great surprisingly..what is the best was to fix this.. . SEM paint hasn't came in. really dont matter tho, i have to get this fixed before i do anything else. whats yal's thoughts how bad is this. the rest of the car looks great will make more pics later its wet and nasty here.
080e5315-cc26-4b4f-9514-14c82392a383_zps6d56cf72.jpg?t=1389638090
passenger floor pan.
efb8867f-49d3-42d0-8ec2-e9fa2b821479_zps2f7be6e7.jpg?t=1389638051
here is the driver side not as bad but there is some little holes
1f104387-674f-4ead-a35f-aa1a6434c813_zps1887794b.jpg?t=1389638284
driver side front floor pan
ecc155bb-75d9-4011-b7c7-0a68aa88b7d5_zps804de0bc.jpg?t=1389638703
.. this kills me.. i have the interior completely out and everything else looks great surprisingly..what is the best was to fix this.. . SEM paint hasn't came in. really dont matter tho, i have to get this fixed before i do anything else. whats yal's thoughts how bad is this. the rest of the car looks great will make more pics later its wet and nasty here. 080e5315-cc26-4b4f-9514-14c82392a383_zps6d56cf72.jpg?t=1389638090
here was the stock interior.
3864b135-4dec-46ad-9f6a-d525b9404b0f_zps0329470a.jpg?t=1389649224
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
For the stock gray plastic, what in SEM or any other color would come close? I want to refresh some of my interior plastic too. thanks!
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
