Formula cup holders
Car: 91 Z28
Engine: 5.7 TPI
Axle/Gears: 10 bolt w/3.73
Formula cup holders
I saw a pic of a 1990 Formula that had a cup holder assembly on the door panel. Wouldn't these fit with very little effort to the Camaro door panels?
Car: 91 Z28
Engine: 5.7 TPI
Re: Formula cup holders
Did you need to fab a plate behind the panel, or did they use existing holes in the door frame?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I drilled holes inteh door and then pushed the 3 plastic screw retainers into the holes. I used the same square plastic screw retainers as used on Licence plates.... then used the large factory TORX screwes to mount the cupholders.
Engine: 4++,350 & 305 CIs
I "think" all doors at least 89 and up have the correct holes so you only need the retainers and put holes in the door panels .
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
good luck keeping them on the door I have had 3 sets and all have broken it seems if you bump them with your leg they break good luck
Engine: LS1, LB9, L03
Yep, just like the ground effects on the passenger door and passenger front bumper corner, they seem to be broken/missing on at least half of the 91-92 Firebirds I've seen.
Engine: LQ4 ls 6.0
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Same here, had mine for over 15 yrs, no issues.You just gotta keep in mind to lift your leg, so your shoe dont slam into it.Think my 84 had two of the three holes on the door.Look for the square hole/s.
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
someone needs to reproduce these in a better plastic.
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I installed a set of them in my fiero since it has nowhere else to put a cup holder. Covered them in a vinyl wrap to match interior and havent had any problems with them. Im running a 98 trans am console in my thirdgen so it has four cupholders built into it
Linson
Oct 1, 2015 09:50 PM
