Manual Window Regulator
Car: 1987 z28 I-roc
Engine: Carbed 350
Transmission: 700r-4
Axle/Gears: Stock
So my drivers side window doesn't roll up all the way. I took a look inside the door and saw that the top 3 or 4 teeth on the regulator are worn down. I have phoned the local parts stores and no one can find a regulator for me. So, my question is anyone know where I can find myself a new manual window regulator?
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Manual Window Regulator
I have no clue about a new parts, but if your interested in a used one - I might have it. Just send me a Private message with your postal code if a used part is OK.
Car: 1991 GTA
Engine: LB9
Wow, 1AAuto nor Rock Auto carry a manual regulator. I couldn't find one at O'Reiily, or NAPA.
I suppose they don't break/wear out enough to justify having them made.
Used may be your only option
Car: 1987 z28 I-roc
Engine: Carbed 350
Axle/Gears: Stock
Yeah it's weird I have looked all over the place. Found a few used ones on eBay for fairly cheap ($25 or so) then shipping makes it like $80. Gunna try to get one from a wreckers, or have a guy that has both front doors with power windows and locks but he wants 100 each. Then I'm not sure what I'll need to wire them in.
