Dash harness info
Old Jan 6, 2014 | 10:07 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Dash harness info
Looks like I need to do a harness to get rid of all the splice and dice the POs did to my under dash harness. what years should I look for? Will a camaro one fit (doubtful)?
Old Jan 28, 2014 | 11:51 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
Re: Dash harness info
digital dash or analog?
Old Jan 29, 2014 | 07:51 AM
Veaceonee's Avatar
Analog. Auto
Old Jan 29, 2014 | 10:38 AM
Axle/Gears: 3.45
Definitely don't get a Camaro harness as that won't be compatible with your GTA. As for which years to look for for a compatible harness I believe any between 85-89 will work. Just make sure it matches up with your power accessory options and all should be good. You also don't have to worry about looking for a harness that came from the auto, as the manual and auto are the exact same.
Old Jan 29, 2014 | 11:37 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The best matching harness will come from an 88 Firebird with TPI. Second best choice would be from an 89 Firebird TPI.
There were a lot of changes from pre 87-to-88 so I stear clear of those if possible. ( 87 dash harness stops at the drivers kick panel,.. 88+ dash harness ends all the way at the back of the car ) 90-92 are Speed Density TPI's so I'd stay away from those unless you are converting your TPI to keep things 'simple'.
Old Jan 30, 2014 | 01:22 PM
Veaceonee's Avatar
There is an 87 firebird that just got to the junkyard. It is most likely a V6 car (havent seen it yet). Would the harness out of that car work?
Old Jan 30, 2014 | 06:03 PM
John in RI's Avatar
Please; Re-read post #5.
Old Jan 31, 2014 | 02:51 AM
Veaceonee's Avatar
Dam...didnt see that. Oh well.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
