Panel alignment issue
Old Feb 15, 2014 | 07:51 PM
Dezined's Avatar
Car: 91 Camaro RS - B4C option
Engine: L98 5.7l V8
Transmission: 4 speed auto
Is this normal? Can't be. I have adjusted the hell outta these two panels, and can't get this to line up. Is there something I'm missing? It seems like the hole for the privacy shade bracket is cut to low, but it's a factory cut piece.
Thoughts/suggestions welcome!
Old Feb 15, 2014 | 09:16 PM
jrhaus76's Avatar
Car: 1989 IROC-Z28
Engine: L98 - 350 TPI
Transmission: MD8 - 700R4
Axle/Gears: GH3/G80 - 2.77 POSI
It should line up better.
Old Feb 16, 2014 | 07:54 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Panel alignment issue
Def not correct, but hard to say what's wrong without messing with it. My guess would be the shade mount is bent or something.
Old Feb 16, 2014 | 09:59 AM
Dezined's Avatar
Engine: L98 5.7l V8
Well damn..... I didn't even think of checking the bracket. That might be it. Thanks man
Old Feb 16, 2014 | 01:36 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
The panel is supposed to tuck under/into the weatherstripping.
Try not using the plastic screw and see if you can mate up the panel to fit.
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
deracer
Apr 11, 2016 12:04 AM
tcflint
Sep 14, 2015 04:55 AM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
