climate control Blower problem
Old Feb 21, 2014 | 02:44 AM
blp226's Avatar
I have a 92 RS V6. It's a "fixer upper" When I bought it the blower doesn't come on. When I turn the slow/med/fast switch/**** on the climate control panel it makes the clicking noise, but will spin around and around. The blower never comes on. I ran a wire from the battery to the post on the blower electrical connector under the hood the blower came on and ran. I replaced the relay under the hood as well as the gizmo that is inside the heater box under the hood that has an electrical plug sticking out of it and inside the box there are some metal coils. It's held in the box with 2 screws. Is this the resistor? Doesn't matter, I replaced it. The blower still doesn't come on. I'm tired of replacing various parts, how do properly diagnose whats wrong? All I have is a basic circuit tester and a continuity tester. I have no way to check ohms or anything.
Old Feb 21, 2014 | 04:42 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: climate control Blower problem
Those coils are the resistors all right. Basically you seem to have an issue with either the wiring between the switch and the blower or with the switch itself.
What do you mean by "clicking"? Do the vents click or just the switch when it enters another position?
Old Feb 21, 2014 | 05:03 AM
blp226's Avatar
Just the normal mild click, click, click when I change to each higher or lower fan speed, but after 3 or 4 clicks it will stop for a few positions then make the clicking some more. I think fan switch is bad but there doesn't seam to be any climate control panels for sale at any of the parts houses and I don't know how to diagnose it to know for sure.
Old Mar 5, 2014 | 12:56 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
After 3 or 4 clicks? IIRC, there's only 4 positions for the switch, including the off-position, no more.
So if there's more, I'd guess that switch has died.
soarestransam
Sep 1, 2015 04:00 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
tnrednneck
Aug 13, 2015 08:57 AM
