center console repair?
Old Mar 18, 2014 | 08:11 PM
mack1985transam's Avatar
Car: 1985 trans am
Engine: 355 vortec built 4 bolt main
Transmission: 700r4 w/ shift kit b&m console mega
Axle/Gears: 3.08
Just wanted some oppions on this center console repair. I put in a b&m megashifter for our cars and deciede it was a good time to reglue the vinyl that was pellung away. Beside the peeling the center console is perfect. I have a new shifter plate on its way. I put glue all in between the vinyl/foam and plastic then clapped it for tonight I am anxious to see if it will hold by tomorrow morning. I just used a crafts and art multipurpose glue. It is suppose to be for vinyl plastics and leathers ect what do you guys think will it hold?
Old Mar 19, 2014 | 09:11 AM
Car: 1985 trans am
Axle/Gears: 3.08
Re: center console repair?
I didn't work with that glue. The glue is Sobo so don't use it. I am going back tonight with gorilla glue. Also I wouldn't remove any foam that would distort the look after repairing. So I will grab some gorilla glue then clamp over night then reupdate. I'm thinking the gorilla should hold!
Old Mar 19, 2014 | 01:30 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Ok, thanks for the heads up. Gorilla glue should work. Now that you mention it I think I recall reading about using that.
Good point about the foam. I was thinking about it coming loose from the vinyl.
Old Mar 19, 2014 | 08:09 PM
Car: 1985 trans am
Axle/Gears: 3.08
Okay got the gorilla glue and gummed it all up in the center console. I clamped it all down and let it sit for a little over an hour. Bonded like a new born to a nipple! Great stuff the area j repaired almost looks better than the rest of the center console that wasn't peeling! Highly recommend this repair! It will make your peeling vinyl stick right back to the center console! Now that I have repaired it the center console is in perfect condition! Sorry I can't take pics they wont upload....
Old Mar 19, 2014 | 08:23 PM
Scorpner's Avatar
Engine: V6, V8
That's great! I’ll keep that in mind when I do mine.
Old Mar 25, 2014 | 11:48 PM
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
Good info. Just one question. My plastic top is also coming free from the vinyl bottom, but there is also some "rippling" in the vinyl at the top lip where the sides turn down to meet the plastic. Any good way to straighten that back out again? Apply heat maybe? IDK. And those 90 degree angles on the right side are not close to right. I may need to post pics. I'm also considering replacing the carpet, so I guess I'd better wait til I decide on that before using Gorilla glue to tamp it down.
Old Mar 26, 2014 | 12:10 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Mack,
Thanks for the tip on Gorilla Glue. I already have a bottle in the shop, I think.
I just bought an '88 T/A, which has this bit of damage on the side of the console.
On the right /driver side, from the about the power window switch forward, it is pulling away.
Is this the sort of damage you were able to repair?
Old Mar 26, 2014 | 06:47 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I have fixed those side bulges.
Use the plastic weld epoxy. Get the plastic weld inside the vinyl covering and use clamps to squeeze everything back into place.
Old Mar 26, 2014 | 08:26 AM
Car: 1985 trans am
Axle/Gears: 3.08
Synopsis Dave yes that is exactly what I fixed brother! Its like the common cold to our cars! And don't try anything other than gorilla glue! Nothing else works as well two part epoxy don't have anything on gorilla glue. Also one tips I didn't wet the area like gorilla glue recommends and it still.cured just fine! Don't wet in fact because it will expand too much. Just make sure you cut a piece of wood to.clamp to.the sides with lots of clamps. I will try to post before and after pics anlong with clamp pics.
Old Mar 26, 2014 | 08:27 AM
Car: 1985 trans am
Axle/Gears: 3.08
I meant dyno Dave sorry
Old Mar 26, 2014 | 12:40 PM
DynoDave43's Avatar
That would be great, thanks!
Old Apr 8, 2015 | 06:41 PM
darren8642's Avatar
Will this permanently affix the console to the black plastic top cover or am I reading the method of the fix wrong?
Old Apr 8, 2015 | 06:52 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
No, you remove the top and run a bead of glue(underneath) then clamp it down,I used paint stirrer sticks and a couple clamps.
And also I used s Hot glue gun and it worked very well,still holding.
Old Apr 20, 2015 | 12:45 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
"Bonded like a new born to a nipple!"
Love it!
I also used Gorilla Glue . Worked like a champ. Just remember the glue will expand to 4X it's size, so be careful on the amount used.
AND a buttload of clamps!
Old Apr 20, 2015 | 03:57 PM
DynoDave43's Avatar
Good timing Bob! This is something I hope to address this summer.
Old Apr 20, 2015 | 04:30 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Dave, I've been putting this off on the TTA. Finally did it yesterday. It took about 1/2 hour to take the plate up and out and then test all the places to put the clamps. Going out now and take the clamps off. (Been 24hrs!) And take a few pics
Old Apr 20, 2015 | 04:37 PM
DynoDave43's Avatar
Look forward to seeing the results!
Old Apr 20, 2015 | 08:18 PM
Bddbrd86's Avatar
Car: !986 Firebird
Transmission: th350
I used black silicone to repair mine. Worked real well.
Old Apr 20, 2015 | 09:07 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I use 3M products to glue mine after i clean the plastic and glue surfaces with a wax and grease remover.
I also use clamps and wood sticks just like that..
Old Apr 21, 2015 | 07:05 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Ta Da! It worked and set up nice.
I'm pleased with the results!
Old Apr 21, 2015 | 07:40 AM
mantaguy's Avatar
Engine: 5.0 EFI
Good job Bob
Old Apr 21, 2015 | 08:48 PM
DynoDave43's Avatar
Huh. So THAT is what it's supposed to look like.
Nice work!
Old Apr 21, 2015 | 09:13 PM
TTOP350's Avatar
Well done!
Old Apr 22, 2015 | 07:04 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Thanks. It looks soooo much better. Thing is, my 85 console is FLAWLESS. The 88 and 89 needed the repair. I did the 88 repair in 89...only a year old at the time!
Old Apr 22, 2015 | 12:18 PM
DynoDave43's Avatar
Old Jul 5, 2020 | 12:23 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Op it is your car, your money(I assume) but you will be spending money, to lose value. Good luck!
Old Oct 17, 2020 | 02:10 PM
BytePaul's Avatar
Transmission: ...was received.
lol, i think the op did whatever he had to do a very long time ago! when responding, make sure you check out the post date.
Old Jun 13, 2025 | 08:58 PM
Penguin James's Avatar
Car: 1988 Firebird Formula
Engine: 305 V8 TPI LB9
Transmission: 5 Speed Manual BorgWarner T-5
Axle/Gears: Borg & Warner 3.45 RATIO
Thanks for the tips I think this will be my next project.
Lbibb
May 5, 2016 12:00 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ndndndnd
Sep 28, 2015 08:00 AM
