cluster swap and now tach is way off
Old Mar 30, 2014 | 12:11 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I just swapped my v6 cluster for a v8 115 mph cluster. Problem is now, my tach is horrible off. Idling, where the old cluster said like 750 rpm, the new tach is at 5500 rpm. All the way around. Start driving or giving out had and it pegs over till you idle. Also when I turn the car off of goes to 7000 rpm or the peg point. Help?
Old Mar 30, 2014 | 06:40 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: cluster swap and now tach is way off
I assume that's the issue. V6 clusters are a straight swap for a V6 as are V8 clusters for a V8. Vary from that and problems are bound to crop up.
JamesC
Old Mar 30, 2014 | 07:06 AM
Engine: L31 350
I'm lost James? Iv got a v8 in my car.
Old Mar 30, 2014 | 07:21 AM
JamesC's Avatar
Ah, swapped as in traded. Thought you meant you'd swapped a V6 cluster into a V8. I'd guess the cluster either isn't seated correctly or the tach is bad.
JamesC
Old Mar 30, 2014 | 10:03 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Highly likely your "new" tach is bad. A very common problem with our cars.
Old Mar 30, 2014 | 01:18 PM
Engine: L31 350
Is there a way to fix it or?
Old Mar 31, 2014 | 10:19 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
https://www.thirdgen.org/forums/elec...meter-fix.html
Right here. Or you can send it to a member to fix it for about $35
Jeremys87
Jul 14, 2022 09:08 PM
Bstrang6
Sep 8, 2015 04:29 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
355sbcTPI
Aug 19, 2015 04:38 PM
stalkier
Aug 7, 2015 04:49 AM
