GTA Power seat
Car: 88 GTA Notchback
Axle/Gears: don't know
GTA Power seat
This summer i am going to be taking my seats out and try to fix the rails. When the seat is leaned back (not the back, but the whole seat) one of the corners is loose and seat does not sit straight. Plus a lot of other minor issues.
I know it has been done, I just never found out HOW it was done, to put the 6 way power seat track into the GTA and keep the GTA seat. I tried search, and it didn't turn up any how to. Any suggestions? My local junkyard has a few fourth gens with power seats in them.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: GTA Power seat
Are you installing a power seat?I just did this yesterday.the seat will bolt right up to the 6 way.Remove the seat,turn it over and remove the 4 bolts that secure the seat to the rail.Make sure you get the harness,it's a plug and play.
Engine: 5.0 EFI
Re: GTA Power seat
The top pic is the panel that the switch is mounted and the bottom pic is the harness that your going to have to get with the seat.
1992 Trans Am
May 10, 2023 07:19 PM
