removing door panels without power.
Old Apr 15, 2014 | 10:02 PM
BrutalGTA's Avatar
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
I've taken my 89 GTA down to bare body in preparation of a full/semi full restoration.
My interior is completely gutted except the door panels. My top plastic trim is in great condition and I don't want to ruin them. I've unbuttoned the bottom of the panel and tried stripping back the window motor wires to "jump" the motor but I'm still unable to get the window to come down.
Does anyone have experience doing this or any suggestions?
FYI- there's no battery or cables to connect one to anymore.
Old Apr 16, 2014 | 06:59 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: removing door panels without power.
Very carefully LOL!
What I have done in the past is pull the panel back enough that I could slip a long screwdriver up to the first tabs that lock the trim to the door and do a push/pull combination to release the tab. Then move to the next one, etc. It is a tedious process. Hopefully someone can come a long with an easier method.
Old Apr 16, 2014 | 10:19 PM
BrutalGTA's Avatar
Car: 1989 GTA
Originally Posted by Zane M
Very carefully LOL!
I've considered and tried this without luck, too damn nervous to damage the upper trim. If this is my only option, do you know about where the clips are?
I haven't removed 3rd gen door panels in 10+ years.
Old Apr 16, 2014 | 11:26 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There's wires running out of the door. Two of them need a 12v circuit and the window rolls down.
Old Apr 17, 2014 | 06:43 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
with the panel loose everywhere else use a block of wood to tap it forward-towards the side mirror. it should slide right off of the clips. i do this even with the window down.
Old Apr 17, 2014 | 09:22 AM
BrutalGTA's Avatar
Car: 1989 GTA
I've tried this on the two wires coming directly off the motor, stripped them back a bit and used alligator clips and a 12volt battery. Maybe I need to bypass something?
Old Apr 17, 2014 | 09:23 AM
BrutalGTA's Avatar
Car: 1989 GTA
Hmmm, I will try this tonight. Seems too easy! But just might work.
Old Apr 22, 2014 | 05:09 PM
BrutalGTA's Avatar
Car: 1989 GTA
I tried this last night without any luck. It seems the front loosened up but none of the others. How much force should i use to knock it loose.
--no Star wars jokes lol.
Old Apr 22, 2014 | 05:40 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Lift the bottom of the door panel away from the door frame and then try and
slide the plastic top piece forward till its lock tabs move into
the cutaways in the top of the door frame and then the plastic will release
and you can pull it and the door panel up and away from the door frame.
Check this thread for a bare door pic and you can see the cutouts:
https://www.thirdgen.org/forums/atta...-trim-door.jpg
Old Apr 22, 2014 | 07:29 PM
toomany's Avatar
Did you power the wires and ground the battery to the door?
Old Apr 23, 2014 | 06:45 AM
naf's Avatar
naf
If you forcefully tap it with a hammer (using a block between the hammer and the panel) it should slide forward about two inches past the clips. Should take one good whack.
On the widow motor only send power to one of the wires at a time. The motor grounds through the body. Power to one will send it up/other'n down.
Old Mar 16, 2015 | 09:52 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The procedure described is correct. I will add that you can move the top trim piece to either the front or rear and it will release the locking tabs from the clips on the door. I spent many frustrated times removing door trim panels before I learned this trick.
Lon
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
