Seat back adustment
Old Apr 15, 2014 | 10:55 PM
01burb's Avatar
Car: 87 Trans-Am, WS6
Engine: 5.0 TPI
Axle/Gears: 4.10 Posi
Seat back adustment
I have a 1987 Trans am that the seat back lays to far back. Is there any adjustments or stops that need replaced to bring the seat to a more upright position? Thanks
Old May 2, 2014 | 02:55 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Re: Seat back adustment
I have the same issue, with just the drivers seat. I drove the car to work today and it's really annoying. B/c the passenger side is more upright, I'm guessing something is worn on the drivers side that keeps it from locking in a more upright position. I'm going to take a closer look this weekend but on here searching in hopes it was a common issue with an easy fix!
Old May 18, 2014 | 11:56 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
many times the issue is ,the seat frame is bent from abuse. the only remedy in that case is to replace the seat.
Old May 18, 2014 | 07:40 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
We removed it the other week for a closer inspection and that seems to be the case. The mechanism that allows the multiple seat back settings is bent so that the **** doesn't set in final groove for the upmost seat back angle. I tried "fixing" it by squeezing it back together with channel locks but that didn't last long. The entire thing needs to be replaced and mounting point on opposite side of seat is bent too. Also, rivets that hold seat track to seat frame are loose. I'm guessing a prior owner was a larger person based on these issues.
Old May 18, 2014 | 09:49 PM
01burb's Avatar
Engine: 5.0 TPI
Thanks everyone. I will remove the seat this summer and see what is going on with mine. With the summer heat around here I don't like driving it as it is so hot.
Old May 21, 2014 | 02:25 PM
Termn8r's Avatar
Car: 1989 Iroc Z28 Convertible
Engine: V8 5.0 305 TBI
Can't you just replace this part?
http://www.ebay.com/itm/GM-OEM-Seats...13705a&vxp=mtr
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
lee01
Apr 9, 2016 01:56 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
