RAP module, 95 f-body.
Old Apr 27, 2014 | 01:12 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Really like this feature in my s10, but the BCM is too cumbersome, but a 95 camaro RAP will do.Got it wired up & working now.These only stay one for 10 minutes, unlike the s10 @ 20min.Anyone know how to modify these to increase the minutes?
RAP & schematic.If anyone wants to know:
RED= batt+, Blk= Grd.
Brn= Ign, Gry/Blk= Dr pin.
Bl= Rad/wdw, Pink= Pwr Acc
Yllw/blk= Low coolant (not used)
Top relay is radio/window, lower is power acc (whatever that is).Both active for 10min after ign is turned off.I wired the windows to the lower instead.It activates when i open the door & stays on for 35sec after the door is closed.This way i can lower/raise my windows w/out the ignition.I had to alter the terminal at the fuse box because the windows/choke/fan are the same circuit, causing the choke/fan to run on w/ the ign off.
Old May 7, 2014 | 06:19 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Re: RAP module, 95 f-body.
So I was gonna go with this idea. I was then gonna get the 95 style keyless entry/alarm, then I said screw it. I just grabbed an 01 t/a bcm and popped it in.
All in one:
controlled interior lights
battery rundown prevention
Better door locks
built in keyless entry/alarm
built in chime box
installed a better (4th gen) trunk relay b/c of redoing some wiring
eventually I will switch to the built in vats module
the gm bowtie keyfob makes it look stock
and essentially its a brain box
Old May 11, 2014 | 10:52 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Way i understand it, is the ECM controls the BCM.So how did you hook it up?
Old May 11, 2014 | 01:38 PM
steveo_'s Avatar
there's no real interaction between the bcm and ecm in a 4th gen; the bcm works just fine as a standalone.
it's programmable internally; uses the power lock switch, dimmer switch, and a few other normal dashboard controls in a 'programming mode' to configure things like door locking and alarm operation..
so if you're going to use it, you pretty much want to connect the entire module..
the only part i wouldn't use is the built-in starter interrupt relay for VATS; if your starter solenoid goes south, it takes that relay with it, and you can't easily repair that. better to connect that to an external relay or something.
Old May 11, 2014 | 08:36 PM
alex722607's Avatar
Way i understand it, is the ECM controls the BCM. So how did you hook it up?
Alright, well thats the opposite, the bcm CAN control the ecm if you want it to. Brief overview:
You can find the rest here along with schematics:
https://www.thirdgen.org/forums/inte...-so-speak.html
Basically there are three main connectors.
#1- door lock actuators and switches
#2- power= power in, ground, certain light functions and RAP
#3- various inputs and outputs including but not limited to VATS functions (all are optional to hookup, except for the bypass that is), lights battery run down prevention, door jamb switches and etc.
For VATS, my car had it factory, I have both actually --> VATS and the BCM VATS, the latter is bypassed, but in the future, I may switch the VATS to the bcm and lose the stock one.
Old May 11, 2014 | 08:46 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Just as well, i dont have that many functions to run & no vats!
InfernalVortex
Apr 20, 2021 11:31 AM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
RedLeader289
Sep 23, 2015 06:50 AM
