Windsheild wipers stop working when turn signal is used and even touched
Old May 2, 2014 | 10:39 AM
Tzg203's Avatar
The intermittent wiper settings work in my 1992 Chevy Camaro RS but it stops working completely if I use the turn signal and can get it working again by touching it. Do you think the problem is the wiper switch, the actual turn signal assembly or the wiper module connectors.
My rear defrosters are not even working so my visibilty is shot! Button comes on and turns off as should but nothing happens.
Old May 2, 2014 | 01:04 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Windsheild wipers stop working when turn signal is used and even touched
Sounds like a loose wire in the column stalk switch…the one that also has your turn signals, wipers, cruise delay..etc. I never replaced one in the newer Thirdgens with air bags though…
Your rear defroster may be a separate issue all together.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
slade5612
Aug 11, 2015 07:19 PM
Fronzizzle
Aug 9, 2015 01:15 PM
