My fiberglass dashboard
Old May 22, 2014 | 10:37 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Like many of you I eventually had to deal with a cracked dashboard. Unfortunately our choices can be limited due to the outrageously high cost of a new dashboard which I have seen up $425.00! At that point you have a few choices:
1. Do nothing
2. Purchase a dashboard cover which is just a piece of plastic that covers the top and part of the sides
3. Recover it in new material be it vinyl or leather
4. Cover it in Fiberglass
I went the fiberglass route and make no mistake about it, this route by far will take the longest but still be hundreds cheaper than $425!
So to stat with you need to peel off all of the sharp, cracked and hardened vinyl that is covering your dashboard. Good luck peeling it all off without causing any finger bleeding. By the time you remove all of that "leather" you may notice that you now have some chunks and strips of foam missing.
[IMG][/IMG]
To fix this you will need to use some Expanding foam from a can. Just put the foam in all of the pot holes and canyons you have created and let it expand. Any area that is wider than 1/2cm or deeper than 1/4cm will need to be filled. You may also need to rebuild the edges and bottom lip.
[IMG][/IMG]
Then break out the belt sander and go to work smoothing out the entire board, as smooth as you can get it.
[IMG][/IMG]
Next you will be starting to glass it. The way that I prefer is to mix up a batch of resin and then with a paintbrush paint the foam and really let it soak into the foam so that the fiberglass is not just sitting on top of the foam. Then lay down your mat material. I used fiberglass mat followed by fiberglass cloth but lots of people online are just using fabrics from whatever sewing store is in the area. This isn't a fiberglass project that needs particular strength so using a fabric may be acceptable provided you use enough.
[IMG][/IMG]
Old May 22, 2014 | 10:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Re: My fiberglass dashboard
You want to use multiple layers of fiberglass to avoid sanding through and repairing an area. After adding the fiberglass sand with the belt sander and then a longboard/file board sander while adding body filler. Then primer.
[IMG][/IMG]
In that picture you can also see that I opened up the defrost vents and speaker grills.
Next I just threw on a glossy, bright red as a guide coat, which exposed several areas that still needed work.
[IMG][/IMG]
Sand, sand, sand.
Old May 22, 2014 | 11:05 PM
Tibo's Avatar
Car: 1991 Z28 Vert
The next step is to decide what color to paint the dashboard. I ended up with semi-gloss black in a single stage paint. I went with a single stage semi-gloss because it hasn't thrown off a dangerous glare (yet?) while still showing a nicely done fiberglass dashboard.
[IMG][/IMG]
[IMG][/IMG]
You can choose a flat black or a textured black and that would also help to hide some pinholes and an amount of waviness if you didn't have ample time to ensure a show car finish.
Old May 22, 2014 | 11:09 PM
Tibo's Avatar
Car: 1991 Z28 Vert
For the speaker holes and defrost vents I went the easy way. I just went to my local home improvement store and bought some dark colored aluminum window screen. I double layered it, cut it out, shaped it and fit it into place. Not the best solution but it was the best one I could think of that worked best for me.
[IMG][/IMG]
That's just some dust that already is on it in the picture.
You may remember that there were originally 2 or 3 screws in each defrost vent that held the dash down on the windshield side that wouldn't be accessible the way I have it now, which is correct. I am using velcro to keep the front attached.
Old May 23, 2014 | 10:21 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Wow! That turned out pretty nice Tibo....looks great!
Old May 24, 2014 | 07:17 AM
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
very cool!!!
Old Oct 18, 2015 | 10:11 PM
Tibo's Avatar
Car: 1991 Z28 Vert
There are a lot of older cars from the 40's-late 60's that have the dashboard painted the body color. My car is white, would it look really out of place or bad if I painted just the dashboard a White? It's in the convertible.
Old Oct 22, 2015 | 02:50 PM
BADNBLK's Avatar
COTM Editor
Dude that looks great! The speaker grilles with the mesh looks really nice too.
As far as painting white, I think you could do it, if you pull the stripes through the window. I did that on mine back in '05 to one of those caps, but it ended up warping in the sun. Haven't revisited that idea in a while. The glare from gloss was hardly noticeable.
Old Oct 22, 2015 | 07:59 PM
Tibo's Avatar
Car: 1991 Z28 Vert
The car will be striped since it came that way. I have a cowl hood too. I'm bot sure I want to do it anymore since you pointed out I would need to pull the stripes onto the dash.
Old Oct 23, 2015 | 05:09 PM
BADNBLK's Avatar
COTM Editor
You know you could always plasti-dip it in white. It will leave that semi gloss finish and you could try it without being permanent...
Old Oct 23, 2015 | 10:06 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Wow, I think I will! Great idea. Peel off in case of failure.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
