Speedo Cluster
Car: 91 Camaro
Transmission: Automatic
Axle/Gears: 10 Bolt 3.73
Speedo Cluster
I was wondering if anyone has modified or updated there OEM cluster
I have a 91 Camaro and to me its outdated in many ways. I was thinking of pulling the cluster (keeping for resell possibly later on) but was thinking of grabbing some 20 gauge aluminum and mounting Prosport gauges in there for MPH and RPM
Along with other gauges (else where) for monitoring.
I'm coming from imports (not rice status) but monitoring everything is essential with racing and knowing your car. AFR, oil pressure, oil temp, ect...
Just seeing if anyone out there has done such?
Car: 1983 Z28
Engine: 385 Fastburn
Re: Speedo Cluster
I've seen a lot of people build their own gauge clusters.
Your current cluster doesn't have an oil pressure gauge? Maybe the base camaro clusters had less stuff in them in '91, I know the older base models didn't have as many gauges and such.
My Z28 cluster has temp, oil pressure, RPM, speed, fuel and battery. I have a fuel pressure gauge under the hood, wouldn't want to run a fuel line anywhere on the interior. What other gauges would you consider adding?
Car: 91 Camaro
Re: Speedo Cluster
It does have it... Its just not aesthetically appeasing to the eyes.
Its a 91 RS with a complete drivetrain swap from an IROC, 350 roller Converted to carb. Heads, cams, full exhaust, posi rear, 3.73, I can't remember everything. I'll get a more in detail list from my uncle (since he built it)
I planned on getting prosport for the main cluster, defi gauges for monitor gauges.
Engine Temp
Oil Temp
Oil Pressure
AFR
EGT
Water Temp
Car: 1983 Z28
Re: Speedo Cluster
Ah, mmk. Here's some links from folks that have gone that route:
https://www.thirdgen.org/forums/inte...a-lite-c2.html
https://www.thirdgen.org/forums/fabr...ash-gauge.html
https://www.thirdgen.org/forums/inte...ro-custom.html
https://www.thirdgen.org/forums/engi...lt-gauges.html
Car: 91 Camaro
Re: Speedo Cluster
I like the cowl hood gauges as well didn't think about running them that way (4 inch cowl)
Car: 1983 Z28
Re: Speedo Cluster
Yeah, I like the cowl gauges as well, it's a safe alternative to running live lines across the firewall.
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
