Blinker Reset w/ Wheel Turn
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
Anyone know what causes the blinker switch to not click off when you center the wheel after a turn? Mine doesn't do that anymore. I have to manually push the lever up/down to stop the turn signal.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Blinker Reset w/ Wheel Turn
The following like has some pics that will give you the idea:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.autozone.com/autozone/par...h&newYmme=true
That's a aftermarket one,if you want OEM ,Try GM Parts Cheap.Com or go to a GM Dealer.
Engine: 408 LSx
Thank you guys. I'll get the Dorman parts. They make good replacements in my opinion.
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
db057
Aug 11, 2015 10:11 PM
