What are these connectors for?
Old Jun 3, 2014 | 11:55 AM
Cleotiz's Avatar
Hi there,
Recently i bought a 1984 Camaro RS, with a 305 engine put in and a TH700 automatic transmission.
The car was quit a puzzle to me, the previous owner got fed up with it and stopped halfway into his project of making it into wat he wanted.
I allready solved some of the puzzle pieces, concerning the transmission and fuel lines and stuff, because of the conversion.
Right now i am busy rebuilding the interior, and i come across some connectors that i dont know where to put..
Are they options that the car does not have?
Did they used to plug into the TH350 transmission shifter that used to be in there?
I made some pictures, i hope you guys can help me
Thanks, Cleotiz
Attached Thumbnails What are these connectors for?-img_20140603_172500839.jpg   What are these connectors for?-img_20140603_172509066.jpg   What are these connectors for?-img_20140603_172516671.jpg
Old Jun 3, 2014 | 11:57 AM
Cleotiz's Avatar
Re: What are these connectors for?
And these 2.
I suspect they may have something to do with the electric trunk unlock.
Attached Thumbnails What are these connectors for?-img_20140603_172524034.jpg   What are these connectors for?-img_20140603_172536002.jpg
Old Jun 3, 2014 | 12:41 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Ok, I'd like to help you but am a little confused at the moment:
You mention a swap, a TH700, and a TH350-my question is:
Does the car currently have a 700R4 (automatic w/overdrive) transmission or a TH350(3-speed automatic, no overdrive) transmission?
Old Jun 3, 2014 | 12:56 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
It would also help if your photos showed the color of the wires attached to those connectors and the approximate location of where the connectors are located (console, left side of dashboard, etc.).
Old Jun 3, 2014 | 03:00 PM
Cleotiz's Avatar
It currently has a 700r4 with overdrive, it used to have a 350 without overdrive.
I can not make any new pictures now, because i am not with the car, but all connectors come out of the space underneath the shift lever.
Old Jun 4, 2014 | 09:55 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
edit:
actually not really sure what any of them are for, i based my opinion on my '89 but the '84's are different
Old Jun 4, 2014 | 11:12 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The first one on the second post looks like the E-brake light & the second looks like a power seat connector.
The angles on first post makes hard to tell what those are.
Old Jun 21, 2014 | 01:44 PM
Cleotiz's Avatar
Thanks guys, so far.
I made a couple of pictures this time, which might clear things up a bit.
A lot of electrical issues with this car anyways.
There is power on the red wire that goes to the fuse box, but next to that i have no power what so ever, wether i have the ignition on or off, no diffrence.
When i make a bridge in the empty slot (in the fuse box, where there is no fuse) i have power everywhere and power windows and everything seems to work.
But also no diffrence when i have ignition on or off.
:P
All help is welcome, thanks guys!
Attached Thumbnails What are these connectors for?-img_20140621_194820931.jpg   What are these connectors for?-img_20140621_194842842.jpg   What are these connectors for?-img_20140621_194857773.jpg
Old Jun 21, 2014 | 07:08 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
The first thing I bought when I got my '84 was the shop manual. It has all the wiring diagrams you need to help straighten things out. Well worth the cost, available on eBay.
Old Jun 22, 2014 | 01:46 AM
Cleotiz's Avatar
Thanks for the advice man,
I purchased a Haynes repair manual as soon as i got the car.
Though i am not exactly an expert reading those diagrams, they helped me a little, so far.
The connectors that i took pictures of are not described in those wiring diagrams, only the wires themselves and the fuses.
Old Jun 22, 2014 | 01:49 AM
Cleotiz's Avatar
I think you are right about the second picture.
That connector comes from underneath the carpet where the driver seat is supposed to sit.
The first connecter i have to test, i hope you are right
Old Jun 22, 2014 | 10:59 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The first pic looks like it would've gone to the radio.The middle looks to be the neutral safety switch.
Somebody really mucked with it.83 was the last yr for the turbo 350,Half way thru 83 GM drop it & started using the 700r4.
Old Jun 22, 2014 | 11:44 AM
Cleotiz's Avatar
Ik know man,
It doesn't have the original engine also, i hope i can get it running and everything working like it should.
The car dident drive for 20 years!!
Looks like i've fixed the ignition switch problem though.
Where to put the neutral safety switch?
Any idea what the third connector is for?
Thanks so far!
Old Jun 22, 2014 | 01:18 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Neutral safety sw. mounts on the shifter.Unsure of 3rd pic, maybe unused option.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
