Window channels
Old Jun 5, 2014 | 10:11 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Window channels
Does anyone know who sells the window channels?
I took my passenger door panels off today to replace a bad window motor. When I pulled the window up by hand to give myself better access to the motor the fuzzy covered rubber that lines the inside of the front channel pretty much just crumbled to pieces.
Old Jun 5, 2014 | 11:52 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Window channels
http://www.1aauto.com/1982-92-window...=476083&y=1991
Old Jun 6, 2014 | 12:27 AM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
Re: Window channels
Not what he is talking about.
Old Jun 7, 2014 | 07:06 AM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: Window channels
He's talking about the rubber "rail" that is held on the bottom of the window triangle inside the door. I don't recall ever seeing one of those new.
Junkyard should be full of those in the US ? Or ask on the classified section here.
The large rubber parts here :
Old Jun 7, 2014 | 01:44 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: Window channels
I think you are right. Can't find them new anywhere. I did find a couple in a pic-a-part this morning that are waaay more usable than my originals. Mine is a 91 Z and these were out of a earlier 80's Berlinetta model. I hope they are the same.
Old Jun 8, 2014 | 11:08 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: Window channels
update: the ones I got at the bone yard don't fit and are most certainly different from mine. I think they are different because the donor car had manual crank windows and mine are power. Anyway....if anybody needs some window channels for a 3rd gen with manual windows I have them.
Old Jun 8, 2014 | 06:26 PM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Re: Window channels
You could try Modern day muscle. I got some from them a few years back.
Old Jun 9, 2014 | 06:36 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: Window channels
Thanks gholian. They have em!!!
Old Jun 9, 2014 | 08:22 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Window channels
IIRC, there is a difference in the year (82-83, then later models?) that they were made and not the model of the car, or the manual/power option. Try searching 'window triangles'. You may be able to sell or trade the ones you got at the junkyard on here under classifieds. Yours might be more valuable actually.
Edit: You could also try to find the felt material as well.
Old Jun 9, 2014 | 02:24 PM
Re: Window channels
I have 1983 dated ones on my '84, one '89 and one '90 and I don't see any difference in the four triangles.
Old Jun 9, 2014 | 02:28 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Re: Window channels
The triangles look the same, but the channel underneath it is quite different.
Old Jun 9, 2014 | 02:36 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Window channels
82 and 83 are NOT the same as 84+ window channels.
The entire door from 82-93 is build different internally to accommodate the specific 82-83 window channel,... that change took place in 84. The 82-83 window channel can be unbolted into 2 parts; the black "filler" and the channel itself. The 84+ parts are a 1 piece design.
Thought I still had pics,.... but I must have deleted them.
https://www.thirdgen.org/forums/exte...ow-filler.html
P.S. I have both types of window channels available if still needed.
Old Jun 17, 2014 | 06:58 PM
transaero's Avatar
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
Re: Window channels
Hawks has them, you can buy the whole part, or just the weatherstripping itself.
http://www.hawksthirdgenparts.com/pr...cket-Used.html
http://www.hawksthirdgenparts.com/pr...w%29-Pair.html
Old Jun 18, 2014 | 09:52 AM
John in RI's Avatar
Re: Window channels
Here's a picture of the ACTUAL 82-83 specific unit....
Old Jun 18, 2014 | 03:33 PM
Re: Window channels
Interesting, I didn't know about that. Mines (above picture) are dated '83 but they must have been made for the '84 model year so they have the newer design.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
