Defroster help needed
Old Jun 9, 2014 | 07:33 PM
peaceman's Avatar
Car: 82 Z-28
Engine: tuned 305
Transmission: 4 speed
The HVAC selector lever will slidt from vent to heat, but will not move past heat to the defrost mode. Any ideas? Can this be a vacuum issue or is this mechanical?
Any help is appreciated.
Old Jun 9, 2014 | 08:25 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Defroster help needed
I think you may have a bent cable.I had a similar problem like that and the cable had a bend in it.
Old Jun 10, 2014 | 01:04 AM
peaceman's Avatar
Car: 82 Z-28
Engine: tuned 305
Thanks, i'll take a look when i change out the stereo this weekend.
Old Jun 10, 2014 | 08:27 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Originally Posted by peaceman
,...........Can this be a vacuum issue or is this mechanical?
If your car is non-AC,..... It's mechanical. If your car is AC than it's vacuum.
If non-AC then it could be a bent/broken cable.
If AC then it could be a vacuum problem at the heater controller vacuum line connection or the Defroster vacuum lines.
I've seen a dead mouse block a air diverter door from closing before so it MIGHT be a blockage of the diverter door inside the heaters internal air box too. ( weird stuff happens all the time !! )
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
