steering column man/auto differences
Old Jul 14, 2014 | 06:44 PM
fatherson91's Avatar
Car: 1970 K25, 1986 K5
Engine: Both 350s
Transmission: SM465
Axle/Gears: Dana 44/60 10-bolts
PO had replaced the ignition switch/lock cylinder with a non-vats key. When I went to buy a new one for the vats, there were different part numbers for auto and manual trannys. Why? I bought the manual one but I am having doubts. I noticed the current column has a 'key release" off the column the new manual cats lock cylinder has a button. I can get some pics up tomorrow, but hopefully what I describe makes sense. Did I just waste money on the vats manual lock cylinder? Thanks,
Jim
Old Jul 20, 2014 | 11:54 AM
Engine: Both 350s
Transmission: SM465
Re: steering column man/auto differences
I think I answered my own question. Pulled the aftermarket grant steering wheel off and it seems a PO swapped in an older steering column. I have a 92 steering wheel/airbag and it will not fit on the column. In addition, the vats and airbag wiring was all disconnected under the dash. Also, no room for the clock spring.
On a good note, I did get the tach working by replacing R4 with a 196k ohm resistor.
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
Oenone
Aug 29, 2015 07:54 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
