88 IROC Gauge Questions
Old Jul 18, 2014 | 11:33 AM
Cheibu70's Avatar
Several of the gauges stopped working in my 1988 IROC 5.0L convert.
I purchased another gauge cluster but a few things are different then the gauges I have. Could you tell me what car these gauges belong to?
What I have installed in my car:
Tach:
Yellow begins at 5,000 RPM, ends at 5,500 RPM
Red line begins at 5,500 RPM, ends at 7,000 RPM
Oil Gauge
Begins at 0 PSI, Mid line 30 PSI, Top 60 PSI
The Gauges I purchased:
Tach:
Yellow begins at 5,500 RPM, ends at 6,000 RPM
Red line begins at 6,000 RPM, ends at 7,000 RPM
Oil Gauge
Begins at 0 PSI, Mid line 40 PSI, Top 80 PSI
What are these gauges from? can I use them? I did install them, the tach is off but everything else seems to work, fuel, amp, temp, speedo
Old Jul 19, 2014 | 07:35 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 88 IROC Gauge Questions
sounds like you got a v6 cluster,they have the 80 psi oil gauge.you can use them but as you mentioned the tach will read wrong
Old Jul 19, 2014 | 08:28 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
You can just swap out the tach.
If you had multiple failures on your old one you most likely have a bad ground or something on the circuit board on back. You could either try to fix that or possibly get a replacement for it as well.
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
mustangman65_79
Aug 11, 2015 03:17 PM
