Ashtray 12v Outlet
Old Aug 9, 2014 | 07:51 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Ashtray 12v Outlet
I decided to add a 12v outlet to where the ashtray goes. Between the GPS, phone charger, etc, might be a good idea to add another outlet.
Picked up a NOS 4th gen cig lighter and outlet complete from ebay. Also bought the element to attach to the bottom of the outlet and will u=run the wire to a constant power source.
NOS shifter plate
Took a piece of 1/8" plexi (scrap), added some tape to the top, traced out the shape and used a jig to cut out the piece. After smoothed out the edges and hole with a file.
Back looks good
Test fit....seems OK. Lots of space for future accessory button. Will paint the back of the plexi so it will look clear when installed.
Only took 30 min or so.
Old Aug 9, 2014 | 08:23 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Ashtray 12v Outlet
Old Sep 1, 2014 | 04:03 PM
Car: 89 IROC
Finished pic. Painted the back side in a satin. Coming thru the plexi, it looks clear and bright.
Old Dec 2, 2014 | 03:11 PM
88HARDTOPIROCZ's Avatar
Car: 88 Camaro IROC-Z
Engine: L03 5.0L
Axle/Gears: 3.08
would you by any chance be able to give me measurements of the plexi glass plate you made? I am going to attempt to make one but am not with me car to measure
Old Dec 3, 2014 | 06:34 PM
Car: 89 IROC
Length is 5 5/16"
Width is 1 11/16"
Hole diameter is 7/8"
Distance from end to hole lip is 1 1/8"
Don't forget to add the notches to clear the lid hinge.
Old Dec 3, 2014 | 10:13 PM
Engine: L03 5.0L
Axle/Gears: 3.08
thanks a lot one more question would you by any chance know how far from the top and side edges can not be used bc of the ledge it sits on?
Old Dec 4, 2014 | 05:27 PM
Car: 89 IROC
Side edge is 1/2"
The ashtray opening is 1 1/2" wide
KCG
Jun 24, 2020 04:33 AM
Elephantismo
Feb 13, 2019 12:51 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
customblackbird
Oct 1, 2015 04:30 PM
bplessy
Sep 30, 2015 12:14 PM
