accessory fuse blowing
Old Aug 10, 2014 | 02:14 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
So I bought a 92 firebird formula and the accessory fuse keeps blowing. as soon as I put a fuse in it blows and sometimes burns an melts the prongs on the fuse. I looked at all the normal stuff, The cig lighter is disconnected, all the wiring in the center console is good. pulled the headliner and looked at the wiring to the dome light. I don't know what else or where to check. Anybody have any ideas? I would like to be able to open the hatch on the car once in a while. thanks
Old Aug 10, 2014 | 05:09 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: accessory fuse blowing
I would use a meter to check resistance to ground. If it's shorting out that hard it should be pretty easy to see on a meter and you won't go through a bunch of fuses trying to find it.
You can hook the meter up and start unplugging things on the circuit until the short goes away. If you changed anything recently then I would suspect that first. If it still doesn't go away then I would start looking for possible shorts in the wiring like pinched or bare wires.
Old Aug 10, 2014 | 05:17 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
look for the accessory wire from the ignition switch to be pinched under the steering column support bracket. Happened to me.
Old Aug 11, 2014 | 02:07 AM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
thanks guys i will check in the am!
Old Aug 11, 2014 | 03:24 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Aftermarket radio? Check its plug for possible miswiring and whether the breaker still dies when you disconnect the head unit's plug.
Old Aug 11, 2014 | 11:54 AM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
I pulled the radio the other day and it didnt make a difference. OEM harness is un cut and there. Im gonna look at it more today to figure it out.
Old Aug 11, 2014 | 08:48 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
on my 89 FORMULA I had an issue with the headlights and the wipers once. pull the hush panel under the dr side dash, drop the fuse block and you will see a chunk of harness right next to an "L" bracket that supports the dash. roll the harness over and see if the insulation on the wire was rubbed off.
a friend had the same exact issue on his 86 T/A. a few pieces of electrical tape, some foam to push the harness away and all is good.
Old Aug 28, 2014 | 10:14 PM
gmkid's Avatar
When you get sick of blowing a bunch of fuses and wasting money, I usually put a light bulb (12vdc) in series with the fuse that keeps blowing. The light bulb will limit the current in the circuit and save the fuse. If you put the bulb in series and it is glowing at full brightness...you still have the short. If you unplug something that is suspect (for example the cigar lighter with a foil gum wrapper jammed inside causing a short ) and the bulb gets very dim or goes out, you have found the problem. You should be able to use a standard test light. I have done this in the past with various electronic projects (120v a.c. stuff mostly) and it works pretty well. Experiment a bit and have fun with the learning.
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
64goatman
Sep 9, 2015 01:09 PM
