B&M Megashifter...What's in the box?
Old Oct 6, 2014 | 08:06 PM
Dezined's Avatar
Car: 91 Camaro RS - B4C option
Engine: L98 5.7l V8
Transmission: 4 speed auto
I picked up a Megashifter from a friend this weekend. To his knowledge everything was in the box, but it wasn't. Not his fault, but anyway.
It was a 80693. I can't find info anywhere on this, only 692 and 694. It's very similar to the 692, those were the instructions I used to install it. However I think I may be missing a couple pieces from the box.
One, is I don't have they threaded key for the pull handle. Right now it's secured very badly with zipties until I can find a replacement. I have an idea what it looks like, but if anyone could take a picture of theirs for me, I'd be indebted.
Second, I don't have a gear indicator cable like I've seen on other models. The indicator is built into the shifter on a slide on the left side. An LED holder slides into a hole there for it. The indicator plate was there, but the two are off of alignment badly, and look horrid. The indicator plate is see through, and you can see the shifter through it. I can't believe that that's it, it seems there might be some kind of background for the indicator plate so you can't see past it to the console innards.
If anyone could shed some light on these issues, I'd be grateful. Really having a hard time finding what was in the box.
If there's any additional info that would help, just let me know, and I'll see about getting it.
Old Oct 6, 2014 | 08:44 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: B&M Megashifter...What's in the box?
Here are a couple of pics from one I had for sale. IIRC, the indicator from the cable slides along the straight black piece and that also acts as a back drop for the clear window.
I hope you can figure it out from the pics because it's packed away again.
It's a 692 as well, was used in a Thirdgen.
Attached Thumbnails B&M Megashifter...What's in the box?-megashifter-01.jpg   B&M Megashifter...What's in the box?-megashifter-02-sm.jpg
Old Oct 7, 2014 | 08:42 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Lol mine is missing the pin to lockout for a 3 speed. makes first a little weird sometimes.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
