Can't remove front passenger seat belt, ARGH!
I can't get my front passenger seat belt removed, it's frustrating as all hell lol!
Problem is the lower bolt at the rocker panel. When I try to break loose the bolt, the entire metal ear the bolts goes into bends! I've already bent it back once. I don't see anyway to brace it with the plastic housing all around it either.
I need to be very careful not to destroy it as I'm simply replacing the carpet, hand washing the seat belt, and reinstalling it.
Any ideas guys? I don't have an impact gun, only a breaker bar :/ There is ZERO corrosion, they are just in there HELLA tight with this type of grey goop around the threads which was on all of the other seat belt bolts I've removed.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Can't remove front passenger seat belt, ARGH!
Have you tried tightening it slightly first? Seems counter-intuitive, but often works on rusted or really tight fasteners.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
The only thing I can think of is to use a pry bar up and under on the left side to keep it from bending while you try and loosen the bolt
My first thought exactly, but with the carpet out, the metal floor is too smooth with no where to brace it. Maybe if I can enlist a friend to come over and help by bracing it with his foot lol.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
The goop on the threads should loosen with a little heat. A quick pass with a torch should be all it needs. I don't recall the tab you're talking about though.
(and yes that upwards dent in the floor pan is gone now thanks to a towel and a rubber mallet lol)
Nope but I haven't borrowed a heat gun yet. I tried sitting on the tranny tunnel and bracing it with my foot but that didn't work. I tried going tighter and that didn't work but worked well for bending it back into place lol.
If the heat gun this weekend doesn't work, I'll leave it installed and just get a bucket and wash the seat belt in the car haha!
Engine: V6, V8
With the trouble that bolt has been, the latter sounds like a good idea.
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
I realize you stated you don't have an impact gun, but it seems to be the best fix. Soak it with some PB Blaster and hit it with an impact gun. Buy, rent, borrow or take it in...should come out with no issue. The man handling seems to only be destroying the mounting bracket.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Try to use a plumbers torch on the bracket (don't heat the bolt - heat around the bolt.) A heat gun would not be as effective........
Isn't that bracket simply bolted to the inner rocker ?? If so you could simply unbolt it and leave the bracket connected to the belt when the belt is pulled for cleaning.
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
