Seatbelt buzzer?
Old Nov 10, 2014 | 03:46 PM
Rhett86IROC's Avatar
Car: 1989 RS
Engine: LO3 TBI
Seatbelt buzzer?
Where is the seatbelt buzzer located? After I did my LED cluster bulb swap, my seatbelt buzzeris constantly on, even when seatbelt is being worn. Unless I pull pressure on it.
Any idea where it is? I searched but couldnt find anything.
Old Nov 10, 2014 | 06:57 PM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
Re: Seatbelt buzzer?
You have to take apart the door sill plastic and then there is a wire that goes into the seat belt retractor. Just unplug it and it should stop buzzing.
Old Nov 11, 2014 | 11:44 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The buzzer is located to the right of the steering column, same place the signal light clicker is.You need to remove the panel under the dash t get to it though.
Although I don't get why its buzzing from the led convo.Perhaps something else is causing it.What do you mean by " pull pressure on it"?
xbazzarex
Dec 1, 2015 05:25 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
FormulaEngland
Sep 30, 2015 01:50 PM
