Dash cluster bulb replacement
Old Dec 6, 2014 | 09:44 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Hey guys,
Just had my oil pressure bulb go out and wanted to replace it. Went to the parts store and bought a 194. Now I've read a lot of different things about replacing these like disconnecting the speedo cable and needing a new socket.
Here's my questions
On my 86 t/a where are the bolts located to remove it?
Is speedo cable removal needed? and how/where?
Can I just pull out the bulbs and replace it or do I need to replace the bulb holder like in some camaros?
Old Dec 17, 2014 | 11:47 PM
ledman66's Avatar
Car: '85 Trans Am
Engine: 305 LG4 4BBL
Re: Dash cluster bulb replacement
I'm not sure man but id like to know also...bump to top for an answer or direction to look for info.
Old Dec 17, 2014 | 11:50 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Unfortunatly I found there was a bolt holding the trim in behind the ac controls and I don't feel like removing it so I gave up on it until it really irks me but hopefully someone will shed some light!
Old Dec 18, 2014 | 08:46 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
86 does not have a speedo cable, it's a plug in type.Just remove the surrounding panels and pull it out.
Casey Meyers
Mar 2, 2016 10:46 AM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
