Door Handle Options
Old Jan 22, 2015 | 05:33 PM
Grizzenaznopper's Avatar
Car: 1992 25th Anniversary Camaro RS
Engine: 358
Transmission: 5 speed manual
Axle/Gears: 4.10
Door Handle Options
My door handles are cut in half because I have a roll cage. I need suggestions on what I can do to make it look better, or suggestions on a different type of door handle that I could use.
Attached Thumbnails Door Handle Options-door-1.jpg   Door Handle Options-door-2.jpg
Old Jan 26, 2015 | 09:47 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Door Handle Options
One simple solution that comes to mind is to get the door strap style that was used on Cadillac, Suburban, Lincoln, etc.
Lon
Old Jan 26, 2015 | 10:13 PM
Engine: 358
Axle/Gears: 4.10
Lon
Thanks for the the feedback! Could you help me out with what this option is exactly? Im not really picturing it in my head. A picture or link would help.
Old Jan 26, 2015 | 11:52 PM
lonsal's Avatar
Do a search on eBay for door handle strap. There are two basic types. One that has an attachment point on each end, usually mounted horizontally. The second style has a single attachment point at the top and the strap loops down.
http://www.ebay.com/itm/1978-88-GM-G-Body-Door-Pull-Straps-Kit-Buckskin-19/330923861566?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D945efd962b7f48eb8ebf325c9123c4d2%26pid%3D100033%26rk%3D1%26rkt%3D4%26sd%3D330923861566
http://www.ebay.com/itm/Ford-Explorer-Brown-Rear-Hatch-Door-Strap-Grab-Handle-Tan-/151558075694?pt=Motors_Car_Truck_Parts_Accessories&hash=item234990b52e&vxp=mtr
Lon
Old Jan 27, 2015 | 01:45 AM
Irockthedrag's Avatar
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Axle/Gears: 10 bolt torsen diff 3.73
I'm in the same boat my friend, except im don't even have my handles bolted on. I'm currently revamping my entire car and I've done a few mock ups and I've decided to customize the ones I have. I'm recovering my headliner sail panes console and dash pad in new black leather and cloth so I've decided to use the same leather I'm using for the dash and console on the handles to get a nice match.
I'll be cutting the handles just enough to allow the door to close with little gap between the bar and handle and fiber glassing the handles to round and fill the cut outs, then roughing up the handle and adhering the new leather. Basically when the doors closed it will look like the bar is running through the handle but when open it will have a clean, customized look without being hacked up.
I've pondered this problem many times and this is the only real and logical solution I could come up with without either swapping door skins for a custom skin made for drag cars with the pull stile handle as previously mentioned, or just cutting it as you did.
Old Jan 27, 2015 | 06:48 AM
Engine: 358
Axle/Gears: 4.10
I would love to see a finished picture when you are finished. It sounds really interesting.
tglennon11
Sep 23, 2015 05:30 PM
billybob6110
Sep 23, 2015 01:30 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
NiG
Sep 7, 2015 11:25 PM
scottmoyer
Sep 7, 2015 07:06 PM
