1984 Z28 Camaro map light assembly Help
I recently replaced my headliner and some how broke the plastic that holds the two metal prongs for the map light assembly making the dome and maplights not work. I goggled it but cant seem to find where I can get a replacement. Can anyone offer any insight to where I can find one? I searched my local junk yards but the didn't have any that where similar.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 1984 Z28 Camaro map light assembly Help
You mean the part that holds the bulb?? have a pic.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Your best off checking out thirdgenranch.com for a complete used
unit.
The plastic in my light was brittle and broken into pieces so I just
replaced the whole unit for $7 bucks !
unit.
Engine: 5.0 EFI
There's a couple different styles,do you have a pic.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Its called the dome light assembly.
Some have the 2 built in map lights some don't!
Neither Fleabay or 3rd genranch have a used one listed for sale.
GM used them in a LOT of cars from the 80s to the 90s .
My 94 Buick rat has the same dome/map combo light............
A trip to the parts yard is what u need to do.
I know the plastic bulb/prong holder prob. crumbled as mine did!
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Heres a NOS one with out the map lights and only $14 bucks:
http://www.ebay.com/itm/DOME-LIGHT-BLACK-PLUS-COVER-WITH-LENS-SOCKET-1982-1992-F-BODY-CAMARO-FIREBIRD-/321644737603?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ae3853443&vxp=mtr
Engine: 5.0 EFI
http://www.moderndaymuscle.com/inc/sdetail/160/649
is this what you need?
Engine: 5.0 EFI
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Manta.............that won't help. Thats just the outside cover
He needs the inside plastic piece that holds the bulb and contacts.
$25 bucks...........OUCH!
Engine: 5.0 EFI
O,so there's another piece that goes to that?The add doesn't say that,It's from MDM,maybe he should email and ask them if it's a complete light.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Manta.......... If you look at my pic in post 7 you see the light/cover and
note the small tan bulb holder w/wires piece next to it.
That piece gets toasted from bulb heat and falls apart and the bulb drops
outta place the wires then touch and pops the fuse.
The plastic cover is seperate from the bulb holder (except for the map lights
as they are part of the cover assembly. Note 2 sets of wires)
cHEAp plastic crap........seen it several times!
Engine: 5.0 EFI
Yea I see, the one I posted doesn't have that,so that piece is a totally different part
colton_carlson
Mar 8, 2019 12:21 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
