Horn button contact sleeve help?
Old May 20, 2015 | 07:17 PM
1985chevydude's Avatar
Car: 1985 chevy camaro,z28
Engine: crate 350,headers,3in exhaust
Axle/Gears: 308------3.73 auburn unit
Hello,
I was wondering if anyone knew how i could go about fixing the plastic sleeve that holds the contact for my horn button to work i will post a picture to show
Old May 20, 2015 | 07:20 PM
Re: Horn button contact sleeve help?
As you can see the small white collar has cracked with age.<br/>Is this removable<br/>
Old May 21, 2015 | 07:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll have to replace the cam. See post #9 of the following link for a pic:
https://www.thirdgen.org/forums/elec...orn-fails.html
Useful info/pics:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
Old May 21, 2015 | 07:18 AM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
When I pulled the wheel for my car I found mine was broken but someone had hot glued the wire in, was in pretty tight.
Old May 21, 2015 | 09:41 AM
Thanks fellas
Old May 21, 2015 | 12:04 PM
Now can a new reproduction cam be purchased or is that a more junk yard type of piece?
Again the info you have provided is very useful
Old May 21, 2015 | 06:47 PM
jeff1986z's Avatar
Car: '86 Z-28
Engine: 5.0 TPI
It should still be available in Dorman/Help:
p/n 83232 for tilt wheel:
http://www.dormanproducts.com/p-4057...origin=keyword
or p/n 83233 for non-tilt:
http://www.dormanproducts.com/p-1379...origin=keyword
Old Jun 3, 2015 | 11:45 PM
zz3irocz's Avatar
Car: 1986 Iroc Z, red, t tops
Engine: Gm Performance ZZ3
Transmission: Built 700 r4
Axle/Gears: 3.73 Detroit Locker 10 bolt
I just changed my steering wheel and horn button and realized that clip was missing but the horn wire is firmly stuck in the column, the horn button that I took out was a glued together mess so who knows if it will work, guess I'll find out when I get the engine put back in and have a battery again.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
