dash light sockets please helppp
Old Jun 27, 2015 | 04:04 AM
ambainb's Avatar
Car: 86 iroc
Engine: Iron 408 LS3 combo
Transmission: Ram10 T56
Axle/Gears: 3.73 10 bolt :)
Hi, i want to use a 2 wire style bulb where all my warning lights were, know of anything like this that will twist right in?
86 camaro.. i can find replacment sockets but there all stockers without wire leads or conections
Old Jun 30, 2015 | 09:11 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: dash light sockets please helppp
I'm kind of lost on what you are referring to, the dash lights all can be removed from the twist sockets and replaced with standard or led 194 bulbs
Old Jul 1, 2015 | 04:49 AM
ambainb's Avatar
Car: 86 iroc
Im refering to the socket that the 194 goes into, im using the spots where the lights were for chk engine, parking brake, then i have blank red spots im going to use for temp and pressure warnings... the stock style socket uses the grid type thing on the back for power/ ground correct?.. i dont have that anymore, so im looking for a socket to fit, but one that has wire leads so i can hook them up
Thanks, Adam
Old Jul 1, 2015 | 11:36 AM
Caveman305's Avatar
Engine: L03, LB9
ah ok i understand now, i would assume these would work for your needs. they look to twist in and have wire leads out the back, but i can't say for sure they are the correct pattern
http://www.amazon.com/Truck-Light-Socket-Holder-Connector/dp/B00AKX813U http://www.amazon.com/Truck-Light-Socket-Holder-Connector/dp/B00AKX813U
and if you need more than that they have better deals, i saw 20 for $10
Old Jul 1, 2015 | 08:40 PM
ambainb's Avatar
Car: 86 iroc
sweet dude, thank you... ill give them shot, good deal too
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
