stock component?
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
stock component?
Hi guys
Does my unlock mechanism (dunno the proper name) looks stock to you? Or is an aftermarket part?
And what about the metal panel to mount the speaker? Stock? I have some doubts because it vibrates with the basses. Not a lovely thing.
THANKS
THANKS
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Re: stock component?
Both are stock, I solved the rattle by running some self tapping stainless screws round the metal panel as well as making sure the other 4 screws are nice and tight.
Engine: 5700cc
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The vibration your hearing is probably the plastic body-vent inside the door jamb.
Engine: 5.0 Tbi
I can verify that prolonged higher volumes will rattle the screws for the brackets loose, and the holes strip easy. Almost sounds like a blown speaker when it rattles.
Genopsyde
Oct 7, 2015 08:35 PM
theshackle
Aug 23, 2015 03:49 PM
NinjaNife
Aug 23, 2015 11:49 AM
