Dye Interior Plastics?
Old Nov 13, 2015 | 09:43 AM
1nastyRS's Avatar
Car: 1992 Camaro RS under construction
Engine: Building 500 rwhp ls1
Transmission: 4L85E
Axle/Gears: Moser Ford 9" 3.70
Has anybody dyed their interior plastics? I am looking for black panels. Mine are light grey. I can't find any for sale around me, and shipping is extremely outrageous from other places. If you have, or have any pics, post em.
Old Nov 13, 2015 | 12:16 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Dye Interior Plastics?
I don't have any pics, but I've had real good luck with the spray paint made for plastic. I think it's made by Krylon. I just wash them up real good with a scrub brush or toothbrush and some dish soap, rinse and let air dry.
Old Nov 13, 2015 | 02:11 PM
82tarecaro's Avatar
Do a search. There is a good thread on the subject.
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
SEM is your friend
Old Nov 13, 2015 | 03:51 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Originally Posted by hectre13
SEM is your friend
Hectre is right!
http://www.semproducts.com/refinish-...oattm-aerosols
They have bulk liquid too.
Old Nov 13, 2015 | 03:52 PM
Fox118's Avatar
Car: 89 Firebird
Engine: None
SEM is your friend
+1
SEM colorcoat or SEM classiccoat.
I also used bullydog adhesion promoter and SEM vynil prep.
I did an 88 truck, dyed an interior that had 300,000 miles of alabama clay in the tan plastic AND someone had spraypainted part of it black.. looked like a brand new grey interior.
I plan to use SEM landau black in my car. (it's black already..) and graphite on the console and other grey parts.
Old Nov 13, 2015 | 05:14 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
SEM is great for color, but is pricey. For all of my black parts I used Dupli-color (#HPV106 Flat Black) from the local auto parts store. Haven't had any issues and the coverage was nice and smooth. Dupli-Color has a ton of colors, but none of the parts stores carried the color of tan I needed in that brand. I want to say the dupli-color can me $8-$9 for a 11oz can and the SEM was right at $15 for a 12oz can.
There is a process to it though if you want it to last. Here is what I do:
Scrub all of the parts with dish soap and warm water using a scrub brush (like one to clean under your fingernails), a non scratch Scotchbrite sponge, and an old tooth brush. Once they're all clean I rinse them with water and dry them.
Next I spray each part with prep spray (Dupli-Color #PS100) and wipe it down with a lint free cloth.
Then I spray on two or three light coats of adhesion promoter (Dupli-color #CP199) waiting 3 minutes between each coat.
Finally I spray two to three color coats waiting 3-5 minutes between each coat.
Depending on the weather and the color it may take a different amount of color coats and the dry time could be different. I didn't put cleat coat on any of my panels since my car is garaged 99% of the time and isn't my daily.
Old Nov 13, 2015 | 05:16 PM
1nastyRS's Avatar
Transmission: 4L85E
Originally Posted by Fox118
+1
so what procedures do i take to dye (paint) my plastics black. only my plastics. whats the best coat?
Old Nov 13, 2015 | 05:39 PM
1nastyRS's Avatar
Transmission: 4L85E
have you done this to your third gen?
Old Nov 13, 2015 | 06:36 PM
jharrison5's Avatar
Car: '87 IROC
Yes I have done this to my '87 IROC and to a few other vehicles over the years.
All you are doing is basically painting the panel a different color. You aren't actually dying it at all, so the procedure is what I listed before. Scrub and rinse with soap and water, degrease with paint prep, couple of coats adhesion promoter, spray with color coat and let dry, done.
The stuff you're looking for is called "vinyl and fabric" coating. There are different ones out there, I have just used these two and have had good results with them.
Here it a grey panel I painted Saddle Tan with SEM Color Coat.
Front of panel in saddle tan
back of panel where you can still see the original gray color.
Old Nov 13, 2015 | 07:11 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Ditto on scrubbing them clean and drying in the sun or this time of year with a hair drier before applying.
Old Nov 13, 2015 | 09:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Here's a step by step instruction thread on painting interior plastics.
I still can't believe this thread is not a stickey.
https://www.thirdgen.org/forums/inte...ic-carpet.html
Old Nov 13, 2015 | 10:30 PM
jharrison5's Avatar
Car: '87 IROC
Bingo! Just couldn't remember where to find it lol! It isn't a tough job to do, just time consuming. Prep is the key though... skip the prep and your paint will just peel off.
Old Nov 13, 2015 | 11:10 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
I have a Black interior in MN.
Old Nov 14, 2015 | 10:59 AM
mantaguy's Avatar
Engine: 5.0 EFI
EXACTLY!!!
Old Nov 14, 2015 | 12:46 PM
1nastyRS's Avatar
Transmission: 4L85E
so what do you guys prefer? SEM or DupliColor?
Old Nov 14, 2015 | 03:02 PM
jharrison5's Avatar
Car: '87 IROC
Depends on the color you're looking to do and how accurate you want the interior to be. Like I said before I used Dupli-color for the black parts, but I also use the Dupli-color adhesion promoter and prep spray. The only reason I went with SEM was because Dupli-color doesn't make the saddle tan I need for my interior.
In my experience they both give the same level of coverage and the quality seems to be the same. Since you're doing all black I would save some money and go with Dupli-color since it is half the cost of what SEM runs. Also SEM can be a little hard to find. There is only one place here in Lincoln that carried the color I needed.
Old Nov 14, 2015 | 03:38 PM
88RS's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
I'm a big big fan of this stuff here:
Hi-Tech Industries HT-470 Vinyl, Plastic, And Carpet Dye, Black: Amazon.com: Industrial & Scientific Hi-Tech Industries HT-470 Vinyl, Plastic, And Carpet Dye, Black: Amazon.com: Industrial & Scientific
I tried Krylon before I tried this, ans had terrible results. It really didn't stick well at all for me. I have used Hi-Tech dyes for a couple of different car projects and have always been pleased with the results. I have personally used the black and charcoal. It does give fabrics a dried out feel but it looks great, match was perfect in my Dakota. On plastics it makes them look like new. I haven't used it on anything like a console lid though, have never used it with an adhesion promoter either.
I had to use SEM for an odd blue on a console lid for my Capri. I used an adhesion promoter with it, and while it stuck well, it did dry it out a lot and caused it to crack. I used an air brush to apply it. The match was perfect, but the stuff wasn't cheap. I'll have to do another one again sometime, I have a better crack at winning the lottery than finding interior pieces in this blue.
Old Nov 14, 2015 | 04:14 PM
1nastyRS's Avatar
Transmission: 4L85E
thanks, ill be doing this soon
Old Nov 14, 2015 | 04:31 PM
1nastyRS's Avatar
Transmission: 4L85E
also, what black would i paint it?
Old Nov 15, 2015 | 02:05 AM
jharrison5's Avatar
Car: '87 IROC
I used the #HPV106 flat black and it isn't a true flat more like a satin. It has a slight sheen to it and made my parts look brand new. If I had original packaging I could pass my freshly painted parts off as NOS.
Unless you're looking for a high gloss interior i would stay away from the gloss version. I bought a can by mistake and it was very shiny.
I have been collecting interior small parts for some time and when I'm done with my interior I'm going to start redoing those parts to sell. I've been into 3rd gens for a while and know what parts to look for when I'm at the meets and local yards. A lot of this stuff isn't being reproduced yet and eventually there will be a market for good condition original parts.
Old Nov 15, 2015 | 12:20 PM
1nastyRS's Avatar
Transmission: 4L85E
thanks man, really helpful!
Old Dec 2, 2015 | 08:47 PM
88lt1's Avatar
Check out Colorbond. It is for vinyl, plastic, and leather. They have factory colors and work great. You can paint the part and in 45 seconds scratch it with a finger nail and it stays on. It isn't like paint it actually bonds to the part instead of covering it.
mchaney
Apr 13, 2016 06:02 AM
alexIROC86
Interior Parts Wanted
Jan 24, 2016 01:51 AM
jaridjohn
Convertibles
Nov 9, 2015 08:23 AM
ratinfested
Oct 26, 2015 06:31 PM
legendaryhero7
Oct 23, 2015 08:27 AM
