84 Bird outer AC Vents - how to remove
Old Nov 17, 2015 | 03:22 PM
Buickstaged's Avatar
Car: 1984 firebird se
Axle/Gears: 373
I am trying to take out the outside square ac vents - I cannot find any info on how to do it. Can anyone help me out? thx byron
Old Nov 17, 2015 | 09:44 PM
Axle/Gears: 373
Re: 84 Bird outer AC Vents - how to remove
Help. 33 views and no response? Does that mean they don't come out?.. Thx b
Old Nov 17, 2015 | 11:33 PM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
The outer square does not come out. The two swiveling diffusers do. They have a plastic pivot pin on each side that fits in an indent in the plastic frame. Take a palette or putty knife and slide in between the diffuser and the frame to release the pivot pin. may have to do both sides at the same time, been several years since I replaced mine. There is a thin plastic shim between the two parts also if I remember right.
Old Nov 18, 2015 | 06:45 AM
Axle/Gears: 373
Hal87, thank you.. I will give it a go. Thanks, byron
Old Nov 18, 2015 | 02:22 PM
MNformula350's Avatar
They are held on behind the dash with 2 of those small 7-8mm screws.
Old Nov 19, 2015 | 06:52 AM
Axle/Gears: 373
Thank you for your response. Due to filthy Ac tubes, I took out the entire dash to clean. Was able to take apart. Where are you located in MN? Thx .. Byron
BrianI
Car Audio
Feb 21, 2016 12:26 PM
xbazzarex
Exterior Parts for Sale
Nov 14, 2015 07:49 AM
LiquidBlue
Nov 9, 2015 10:24 PM
72SSboy
Oct 16, 2015 03:27 PM
Camaro_hunter_d
Car Audio
Jun 19, 2001 09:23 PM
