Window fogging, humid rainy days..
Old Dec 2, 2015 | 08:32 PM
phasevariance's Avatar
Car: 1992 Camaro RS & 2014 Camaro SS V8
Engine: 305 & 6.2L
92, RS
It's a pain to drive in rainy weather (not that I want to) I almost never drive the car in bad weather. But those times I do...
Window fog. Sucks. Wipe off, comes back. Vents are blowing, Ac works, Heat works. So what else could it be? Settings on defrost...blowing on window.
It just doesn't seem powerful enough hot or cold.
Maybe the blower motor?. Vents not fully opening? Not sure.
Old Dec 2, 2015 | 09:14 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: Window fogging, humid rainy days..
Quite possible damper not swinging all the way over to force all the air up to defrost vents. Damper is down in/near the heater coil box or right next to it. My 90 iroc damper is there .... Is air leaking out anywhere else /other vents while in defrost mode ?
when you slide the HVAC temp selector lever the cable should open/close waterflow to the heater coil. Also if you hear a hissing sound there is a vacuum valve in there that operates the actuators,. If Vac leak then maybe the issue. There was a repair vid on YT fixing the vac valve to better operate the actuators/dampers.
Old Dec 3, 2015 | 11:29 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Are you sure the heater core's not leaking? Just because you have heat doesn't mean it doesn't have a leak...
Old Dec 3, 2015 | 11:57 AM
aroto's Avatar
Car: 1984 Camaro Berlinetta
i'm going with the heater core guess. mine did the same thing. replaced the heater core
Old Dec 3, 2015 | 01:50 PM
Engine: 305 & 6.2L
The heater core was replaced not long ago. No evidence of leaking. I'm leaning towards damper because it sure takes it's sweet *** time switching from settings or some type of vacuum.
I wish I could just throw a turbo blower motor in there and be done with it. heh
Old Dec 3, 2015 | 08:15 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Im voting heater core
Old Dec 5, 2015 | 12:52 PM
Engine: 305 & 6.2L
There might be something else going on, the car was overheating a bit the other day.
Old Jan 6, 2016 | 04:43 PM
blascwil's Avatar
Car: 1987 Z28 coupe-hard top
Engine: 5.0 Ltr/305 ci 4 bbl carb
Transmission: 5 speed manual
Axle/Gears: RWD - Stock gears
Was the replacement heater core a new AC-Delco OE, or a new aftermarket brand? OR was it repaired/used? Was it air tested prior to installation? Also heater core could have been damaged during installation. It does sound like it is seeping a little. You would not notice a leak under those circumstances. I would pressure test your cooling system first, to rule out the heater core. Good luck.
Thirdgen89GTA
Apr 6, 2016 08:02 PM
B4C5.7
Exterior Parts for Sale
48
Feb 3, 2016 07:25 AM
jorgeblancojr
Dec 8, 2015 08:21 AM
Terry0690
Dec 4, 2015 06:33 AM
Artic-Trans am
Dec 3, 2015 03:46 AM
