visors?
Old Mar 15, 2016 | 10:11 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
visors?
is there a difference between hard top and t top sun visors? if so what is the difference? thanks in advance.
Old Mar 15, 2016 | 10:45 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: visors?
The T-Top and convertable type are curved a little. The hard top are flat.
Old Mar 15, 2016 | 11:15 AM
Re: visors?
Will they work or will they look stupid? Having a hard finding a cheap t top pair of visor's, but have some hardtop ones available.
Old Mar 15, 2016 | 11:23 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: visors?
If you want new, Classic Industries has them for $89. If you want old, put your request on the Parts wanted section.
PS: Flat won't conform to the roof. They will stick straight out at you a little instead of rolling upward.
Old Mar 15, 2016 | 12:43 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: visors?
I used hard top sunvisors for a while until I redid the original ones. It looked fine :
Old Mar 15, 2016 | 01:17 PM
Re: visors?
thanks solar, think that's what I will do, previous owner tossed the visors and headliner cuz the headliner was sagging . Now i'm trying to track **** down.
Old Mar 15, 2016 | 02:27 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Re: visors?
Hopefully, you still have the visor brackets....hardtops and t-top/convertible visors use different brackets. I found this out when I installed visors in my car. The PO had replaced the headliner, but never bothered to install either the brackets, or the visors. Ended up getting a pair with brackets from Hawk's for Christmas.
Old Mar 15, 2016 | 02:39 PM
Re: visors?
No I don't have **** po threw everything out, thanks for the heads up
Old Mar 15, 2016 | 03:11 PM
Car: 1988 IROC-Z
Re: visors?
The T-top/convertible brackets are closer to a 90 degree angle, and the hardtop brackets have more of a "lean" built into them. The hardtop brackets will fit the car, but the visors will droop downwards, and not sit parallel to the headliner.
Keep in mind, they will work, they just look kinda funny. I didn't realize there was a difference until my visors came in, and they accidently sent me one of each kind of bracket. They sent me the proper one a few days later, and all was well.
Old Mar 15, 2016 | 10:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: visors?
T-top visors are also half the width of hardtop visors.
drewmech
Aug 29, 2016 11:13 PM
Gecz28
Convertibles
May 6, 2016 02:27 PM
1988_f-bird
Mar 15, 2016 01:06 AM
Subjec
Mar 11, 2016 10:21 PM
B4C5.7
Mar 9, 2016 10:48 PM
