T top bag bracket mounting help please
Old Apr 25, 2016 | 06:06 PM
uptboi31's Avatar
Car: 2012 ZL1, 1986 Iroc Z, 1968 SS
Someone who owned the '92 I just bought removed the brackets for the t-top bag to hook the forward straps to. The rear brackets are still attached and the ones on the shelf closest to the rear seat are not attached. I found them in the trunk but the screws are missing. What type of screws can I use to reattach them so I can hook the bag straps to them? What type of material is under the carpet? Is there a built in nut under the carpet or do they just dig into the surface under the carpet? I know the fuel tank is under there and don't want to use screws too long and puncture the tank. Any help would be greatly appreciated. Thanks Mike
Old Apr 25, 2016 | 07:04 PM
AmorgetRS's Avatar
Re: T top bag bracket mounting help please
They are very short screws. There is a bracket under the carpet that is raised from the rear shelf that the screws go into. They don't penetrate the rear shelf but no captured nuts or anything like that, they just go into the metal.
Here is what they look like: http://www.ebay.com/itm/85-Camaro-Firebird-T-top-BAG-BRACKETS-w-Screws-92-90-89-tpi-Trans-Am-82-ttop-/221851614982?nma=true&si=%252Fqf%252Fj9npaUwzbHgDNJlT7QdgYo4%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
If you look at the pictures there are 4 short screws which are the ones that hold the shelf brackets.
91banditt2
Aug 11, 2021 10:54 AM
senior bear
Jun 8, 2019 03:55 PM
wiskerchen019
Apr 16, 2016 05:38 PM
Kevman
Apr 14, 2016 04:42 PM
Falcon50
Mar 30, 2016 02:20 PM
