Another cut connection -.-
Old Sep 19, 2016 | 05:30 AM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
Ok, definitely understood. My Bird was "mutilated" through owners and years... I found these wires cut while restoring some dash parts. Someone could tell me thier function? Is that metal thing the airbag module? Thank you guys!
Attached Thumbnails Another cut connection -.--14390680_10207013350358743_4763749014158029030_n.jpg   Another cut connection -.--14368675_10207013350118737_2664067929827500148_n.jpg
Old Sep 20, 2016 | 10:38 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Another cut connection -.-
First pic looks like the cruise control harness.Can't tell on the 2nd.
Old Sep 24, 2016 | 12:29 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
It would help if you used the correct orientation for the pictures and told us where the picture was. For instance the first picture needs rotated 180* degrees.
Those two light green and green wires are for speakers.
The cut loom of (6?) wires may be the passenger door's window motor, door lock and power mirror or just the power mirror. Does the passenger side door's powered components work?
Old Sep 26, 2016 | 11:06 AM
Engine: 3.1 LH0
All of those components you mentioned seems to be working, cruise control too... I really have no idea what are used for
1Aauto
Sponsored Vendors
Nov 29, 2016 02:41 PM
chanrahan
Sep 16, 2016 01:33 PM
Arctic White 91 RS
Sep 16, 2016 01:23 PM
Nik Smith
Sep 14, 2016 04:43 PM
QwkTrip
Sep 13, 2016 06:57 PM
