Anyone Make 160MPH Gauges
Old Feb 6, 2017 | 03:02 AM
t/aws61985's Avatar
Car: 85-6 TA 85 IROC 82-86 MSE 83 Pace
Engine: Slow ones
Transmission: Noisy ones
Axle/Gears: Weak ones
I have been waiting a long time to see someone, or company make a factory style 160 or more MPH speedometer. I was able, although poorly, make a gauge inlay using the limited tools at my disposal. Anyone know of something like this in production?
Old Feb 6, 2017 | 04:45 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Re: Anyone Make 160MPH Gauges
http://www.dakotadigital.com/index.c...781/prd781.htm
Old Feb 6, 2017 | 04:58 AM
t/aws61985's Avatar
Engine: Slow ones
I am looking for a Oem Exact style but higher than 140.
Old Feb 6, 2017 | 07:29 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The factory gauge is internally mechanically limited to about 145mph iirc.
If you want to get silly, you can cut the electric signal in half to the speedo (with a quick wiring trick from the factory VSS box) and then have the gauge made to read to 280mph
Old Feb 10, 2017 | 05:29 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You can always follow my lead and switch over to aftermarket gauges: https://www.thirdgen.org/forums/inte...i-made-my.html
I got the idea from this member's thread: https://www.thirdgen.org/forums/afte...order-led.html
He has a firebird and while the pictures have diappeared I believe that he was able to use the existing gauge holes to mount the gauges so he didn't have to chop up a bracket and use a piece of ABS like I did.
I thought about getting a 160 mph speedometer but in the end I don't think this car will ever break 140 mph in the quarter mile so I went with the 140. Plus the lower the speedometer displays the easier it is to read quickly.
Here is a GPS based 4" speedometer:http://www.speedhut.com/gauge/GR4-GP...-and-high-beam)
You can still run your VSS to your ecm or you can buy a non-GPS based speedometer for a little less money. But the thought of knowing that I can change gears, rear ends, tire size, rim size and transmissions as much as I want and never have to worry about the accuracy of the speedometer is music to my ears.
