DIY Firebird stereo bezel plotting
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
I have been thinking about how to make my own firebird faceplate that will look stock but that I can manipulate to my needs. It's no easy task as I'm a perfectionist and can't skip the grid texture.
What I'm thinking:
Cut out full faceplate shape from Acrylic.
Cut out shapes required for AC/Stereo/Tablet/DoubleDIN/SingleDIN.
Round edges of holes.
heat and bend lower lip as stock bezel.
Attach OEM-like fasteners on back.
Now the tricky part.
Paint and buff to OEM black shine.
Diecut? some vinyl to overlay the grid for texturing.
Need to find a texture spray that would mimic the OEM texture.
Anybody have any input or better ideas of how to accomplish any of these steps?
What I'm thinking:
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
Re: DIY Firebird stereo bezel plotting
I wonder if some masked-off sand or other media blasting would give the right texture?
Engine: LB9
Axle/Gears: 3.08
Been thinking that a regular textured black spray done in a VERY light coat or two may give the desired texture.
The part I'm most concerned with is the grid masking. haven't figured out an easy way other than buying a computer diecutting machine.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Spray the piece matte black, then apply gloss black over the stencil to create the effect.
Engine: LB9
Axle/Gears: 3.08
A stencil that isn't sealed to the surface will allow anything sprayed or liquid to spread anywhere it wants.
Axle/Gears: 10 Bolt 2.73 Open
That's what I was thinking. Oven cleaner or something that would etch the surface. I think a "thickness" of paint would not look right (and flake off the polished finish).
Totally on board with the stencil idea.
Use someone who does vinyl decals to cut a few sheets of the grid for the stencil. No bleeding issues there most likely.
Engine: LB9
Axle/Gears: 3.08
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
https://m.facebook.com/profile.php?id=100005430974742&tsid=0.13515939330914528&source=typeahead
Get ahold of him. Does all kinds of stuff. Great prices and easy to work with
Engine: LB9
Axle/Gears: 3.08
Will keep them in mind if it's needed, thanks.
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
He's about as close to a member as he's going to get. As he's my brother and unfortunately a buick guy. ( don't hold it against him though)
But I do understand where you're coming from.
But I do understand where you're coming from. Joined: Jan 2009
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
You might want to check this out.
http://www.thingiverse.com/thing:1353274
I've never printed it but it looks good. He's a member on here.
It's about 5/8" too tall if I remember. I had one printed. Like it, was going to have another printed but shorter. However, haven't had time to change the measurements. Other things popping up... yada yada yada. I have a thread about it on here.
Engine: 406, LB9
I'll also add that I've installed an Android single din head unit with a 7" screen. I'm using it with ALDLdroid as a datalogger/tuner. That's my guess to what you're trying to do Vanilla Ice.
https://www.carjoying.com/new-androi...nt-system.html
Engine: LB9
Axle/Gears: 3.08
I always have ulterior motives. Thinking of using this to also create a custom gauge pod that looks factory too.
Engine: 406, LB9
Hope you get something cool figured out.
Engine: LB9
Axle/Gears: 3.08
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
If you can find an original headlamp on/off switch assembly, the grid pattern on there is just a stuck on thin plastic like film. Maybe you can take that to a printer and have it digitally scanned and then copied or printed onto a black transparency like material you can then stick onto the new trim bezel you're going to make just like it is on the factory headlamp switch assembly?
