Need factory Delco stereo
Hi all, I need help locating a working factory Delco head unit for my 87 GTA. It has a aftermarket Kenwood unit but I want it back factory and want to add an aux input on it. Any help will be greatly appreciated.
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Re: Need factory Delco stereo
Look for a Pontiac Monsoon CD player from a 4th gen! It illuminates red and would be a perfect fit in your radio pod opening.
That would be nice, I remember those. I could probably pick one of those up at one of our salvage yards and get the harness with them. Surely the pigtails were changed.
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Yeah-pigtails are different-I have the wiring diagram for it if you need one-PM me your email and I can send you the file. The Theftlock CD players from those years are FAR superior sound/wise compared to the stock radio-even the higher end EQ one.
I'd rather have the one that is correct for an 87 GTA. They both will sound poor compared to even a $100 aftermarket headunit. It's all about the nostalgia if you're trying to put it back to factory, and a 4th gen unit isn't putting it back to factory imo. Might as well keep an aftermarket unit in there...
No one said they would sound the same but they'll both sound much worse than even a new $100 pioneer head unit from Walmart. And a 4th gen radio doesn't look similar and it's not factory correct which is what he's looking for. If not going for the factory look, why not just put a decent aftermarket unit in there?
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Well I agree with that BUT-the GM theftlock head units sound much better than even the optional stock 3rd gen ones and you don't have the theft worry to deal with. I've built plenty of mid level sound systems using them and nobody is the wiser. Nobody would think a car with one of those has amplifiers, subs, etc. lol. I also had the built in EQ curves eliminated and then routed it through an Audio Control processor for even better sound levels....I just prefer clean updated stock head units over aftermarket mainly for the stealth factor. If going full Resto then yeah the scarce EQ GM head units are nice to have....but they lack any kind of power if you want to push even a decent set of component speakers with it imo.
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
This is one of my GP dashes but this gives ya an idea how the GM CD player looks like it belongs there-and nobody will think that his head unit actually runs to a couple of vintage rebuilt Zapco amps and a sound processor....
Car: 87 GTA
Engine: 6.0 LQ4
Transmission: 4l80e
Axle/Gears: Stock
I have one. PM inbound. Worked great when I got my car, I put an aftermarket head in there for Bluetooth.
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Here's another option IF you want CD capability and want to add an IPod input without modding a fairly scarce factory EQ unit. This is from a bonneville SSEI about 1994-95. These are as easy to find in boneyards as finding a rusted out F150! This one was really nice....says Pontiac and also illuminates red as most Pontiacs did-looks factory and doesn't sound too bad imo.
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
That IS a nice factory unit too-don't see them often. See I'd hate to modify a fairly scarce factory unit tho!
Car: 87 GTA
Engine: 6.0 LQ4
Transmission: 4l80e
Axle/Gears: Stock
It it is a good working unit, but I don't see a problem with modding it. I figure if you mod it for aux in , then you might just keep it in the car instead of going aftermarket
i really like the retrosound unit but damn it's pricey
Car: 1984 Trans Am
Engine: Lg4 305
I am considering the same swap could you send me the same wiring diagram
I'm thinking about the same swap could you send me the wiring diagram too
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
Here's the list I made-if works for all GM theftlock style radios like the 96-up blazers and 93-02 Fbodies.
On Probation
Note that the later year Delco stereos use a small pin plug on the rear.
Earlier year (like my 84) has big pins.
I have the delco gold series CD in my 94 Buick rat.
I tried to swap it into my 84 Z and couldn't do it because of the pin size
difference.
I know now that Crutchfield.com has adapter plug ins to solve this problem
without butchering up the wiring harness.
Just check the pin size in your new radio.
Also note that a delco radios from 03 and up are vin# locked so a trip
to a GM dealer Tech 2 will be required to unlock it.
Earlier pre-03? delco theft loc radios can be unlocked following a simple
procedure found elsewhere on this forum or on line.
difference.
On Probation
This is the later small pin style up close.
Top radio is the later CD small pin.
Bottom is the stock 84 am-fm-tape big pin.
