Trans am gta center consle trim
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
Car: 1970 Plymouth Hemi Cuda
Engine: 426 Hemi
Transmission: A833 4 Speed
Axle/Gears: Dana 60
Re: Trans am gta center consle trim
Hi Brian
I had a similar issue on my 88 GTA, and I took it out, which is only a 10 minute job, put it on the bench, got a heat gun on it, and then secured it from the inside under the top plate, and it looks 97% as good as new
Not a hard or long job, but just a bit fiddly
Hope that helps
Hope that helps
Car: 88GTA
Engine: 5.7TPI
And Gorilla Glue. Worked like a champ. Let it set up for 24 hours before removing clamps.
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
this! i did the same with a spare console i had , and worked very well. i have not put it in a car, but its held to its form for over a year now, sitting on a bench in the shop.
Axle/Gears: 10 Bolt 2.73 Open
Yeah, a common failure with the late Firebird console.
I too need to follow Bob88GTA's lead and do this repair on mine. It's not bad yet, but it's not right, either.
I wanna do it to make the interior look better. Its fairly good condition, just minor issues such as the center consle
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
I also used the glue method. Works great and is really cheap. Hard to find a solid console.
